Venting is very important with all castings, and you have to evacuate the air in order to replace the cavity with liquid. The trouble sometimes is trying to think like water and being able to visualize how a mold will fill, and how the air will get out. The "rules" for lost foam are a bit different that traditional casting as I'm learning (the hard way), but the physics are similar.
I posted about this over at the homefoundry forum, and was able to get some great info from Kelly Coffield and others, and have a better understanding of my failure points, and a few more helpful tips to make sure the third time is the last time.
I've never been one to get all that pissed off about failures, as long as I could understand why I failed, and make the proper corrections moving forward. I realize now, my initial molding orientation was probably the best way, and most likely would have succeeded if I had enough sand to cover the pattern by a couple more inches. The undercut area was due to insufficient vibration. That was the reason I rotated the orientation for the 2nd go round, but I didn't think about that orientation being worse for filling/venting. I had my blinders on just thinking about the undercut. So, for #3, I'm going back to #1 layed down, and will take my time vibrating it thoroughly this time to ensure that undercut gets filled. If not, I can always machine that out too.
