Dan Dubeau
Me either, but John and Gerrit sound smart enough to know lol......I can barely spell Parthpilot, let alone modify it!![]()
Well @gerritv knows lots. With respect to Path Pilot I'm on the second day of the learning curve. Finally got the system back from it resetting. But it won't run Path Pilot.Me either, but John and Gerrit sound smart enough to know lol......![]()
David,I'd be interested in seeing your HAL file for my edification.
Before you decide on the 7i92T or the 7i96S we better know for sure that the Path Pilot can work with the 7i96SYou're blazing a trail my friend! I shall soon follow in your footsteps![]()
I only see three limit switches on the TORMACH. Are they effective in both directions?Here's a link to the 225 pg. Tormach 1100 manual:
7i92T or 7i96S? There is no 7i92S...I did place an order for an 7192S but I have a call in to Mesa. Waiting callback from them.
BAH 7i96S7i92T or 7i96S? There is no 7i92S...
BTW. After much painful work and upgrading etc. I finally have the ability to look at the network via WiFi.
limit switches in PP are for homing, everything else is soft limits.I only have three limit switches. X0, Y0 and Z0. Masso uses soft limits for the max positive values.
Please tell me LCNC will do the same....
Same as Masso and UCCNClimit switches in PP are for homing, everything else is soft limits.
Hmmm. If your goal is a simple Path Pilot installation you are in for a ton of work. Here's the list of bit files for the various MESA units. Perhaps the tormach_mill3.bit file will work?Talked to Peter at Mesa.
He said the 7i92s may work with Pathpilot but it may also throw some weird errors and require a bunch of hacking to get around. He knows for fact that the 7i96 does work as Tormach ordered those in the past.
Cancelled my order for the 7i96s and replaced it with a 7i96 instead.
$30USD cheaper to boot![]()
When you look at the hal file you will see this table edited to show what the pins actually do.IO Connections for P2
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort StepGen 4 Step/Table1 (Out)
14 1 IOPort None
2 2 IOPort StepGen 0 Dir/Table2 (Out)
15 3 IOPort None
3 4 IOPort StepGen 0 Step/Table1 (Out)
16 5 IOPort None
4 6 IOPort StepGen 1 Dir/Table2 (Out)
17 7 IOPort PWM 0 PWM (Out)
5 8 IOPort StepGen 1 Step/Table1 (Out)
6 9 IOPort StepGen 2 Dir/Table2 (Out)
7 10 IOPort StepGen 2 Step/Table1 (Out)
8 11 IOPort StepGen 3 Dir/Table2 (Out)
9 12 IOPort StepGen 3 Step/Table1 (Out)
10 13 IOPort None
11 14 IOPort None
12 15 IOPort QCount 1 Quad-A (In)
13 16 IOPort QCount 0 Quad-IDX (In)
# 5i25
# Configuration pin-out:
# IO Connections for P3
# Mill Function Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
# Spindle Speed 1 0 IOPort StepGen 4 Step/Table1 (Out)
# Coolant 14 1 IOPort None (Out)
# X Direction 2 2 IOPort StepGen 0 Dir/Table2 (Out)
# Estop Reset 15 3 IOPort None (In)
# X Step 3 4 IOPort StepGen 0 Step/Table1 (Out)
# Spindle Dir 16 5 IOPort None (Out)
# Y Direction 4 6 IOPort StepGen 1 Dir/Table2 (Out)
# Charge Pump 17 7 IOPort PWM 0 PWM (Out)
# Y Step 5 8 IOPort StepGen 1 Step/Table1 (Out)
# Z Direction 6 9 IOPort StepGen 2 Dir/Table2 (Out)
# Z Step 7 10 IOPort StepGen 2 Step/Table1 (Out)
# A Direction 8 11 IOPort StepGen 3 Dir/Table2 (Out)
# A Step 9 12 IOPort StepGen 3 Step/Table1 (Out)
# X Limit 10 13 IOPort None (In)
# Y Limit 11 14 IOPort None (In)
# Z Limit 12 15 IOPort None (In)
# Probe In 13 16 IOPort None (In)
Well I intend on changing the ini and hal files to match my hardware setup. The first trial will be to tell it to use a different mesa .bit file that matches my hardware. If that works out then to change the HAL definitions to use my pins including the step/dir for the spindle.If I don't get pathpilot working it's definitely not the end of the world
