Probably best to think about it for a month or two before you try...I know, I know.... I hope to try an actual CAD/CAM project tomorrow 🙂
....working on the CAD/CAM now....Probably best to think about it for a month or two before you try...
Thanks Gerrit, appreciate that!Tormach has a hub for PathPilot where you can dry run your CAM: https://hub.pathpilot.com/login?next=/ Free to use.
gerrit
......ummm John, I thought we talked about this. 😉
See guys. It's going to take him forever to get up to the capabilities of @Susquatch Getting his mill working was the best way to slow him down........ tee hee.Ok that went better except I hit the estop just before the drill cycle so I had to try and pick up the X, Y and Z again and I was off a smidge because I didn’t use the probe.
Thanks Gerrit, I appreciate your confirmation of what I learned yesterday.Drilling is absolutely the hardest on shop built CNC machines. M6/.25" is my personal limit. I turn my spindle down to 6000, and use very conservative feed rates. Risk is of course rubbing instead of cutting but doing otherwise results in machine making very unhappy noises.
I switched to using 135dg split point drills, which helped somewhat. Anything close to or over .25" gets bored using 4mm carbide end mill, which will happily run at 15k rpm and fast feed rates.
gerrit
All the CNC based drilling I've done always starts with a center drill (Tool #1), then switches to a small diameter drill peck drilling to make a clearance hole for the tip of the larger drill bits. Then finally peck drilling with the large one. WD-40 for aluminum. Oil for steel.Thanks Gerrit, I appreciate your confirmation of what I learned yesterday.
That was an F drill or .257" diameter so probably too ambitious for my first attempt.
I had set the first peck drill cycle to 500 rpm and what I thought was a conservative feed rate but the drill actually dug in and stalled the servo ending the cycle.
The second time I increased the rpm to 1000 and while it was better the feed rate was still far too aggressive.
I usually choose the intermediate drill bit based on what holes I need and the tip size of the largest drill bit. The 6.35mm or 1/4" really needs at least a 1mm pilot hole but that's really not useful anywhere else. A 3mm drill bit tends to be fine.I think I must have lost part of my brain yesterday when I did the CAM as I went straight from center drill to the .25" drill. I probably should have put an intermediate drill in between.
I can't remember if your motor/spindle is 1:1 or is there a reduction?
