Tool Vevor mag drill 1100w
Tool
Well I ordered the smaller mag drill, variable, reversing with 6 cutters.
Re the fine print of lower price after 'registering', yes make an account with them and your prices in the cart are lower. I imagine they will send ads via email.
Anybody have one of Vevor's battery brad/stapler nail guns? $123? with battery and charger.
I just ordered it. I'll let you know. I mean, how bad can it be? 😳
Everything I've ordered form them has been as good or better than what I buy from Princess Auto so far.
Were you looking earlier or did I spur an impulse purchase? I'd call my ordering of the mag drill pretty impulsive. I've wanted one for a while, and I even bought one from Chaychuck (which I didn't understand how big it actually was, good for bridges and skyscrapers, so it had to go and another forum member has it now)... but I'm not sure how much use this is going to get.
Oh this is 100% your fault.
And the mag drill that's coming as well.
Your fault. All of it. 100%
Isn't that in the rules?
Here is the RULE: To be eligible for renewal every member must convince another member to spend more than they initially intended (usually more than they have) at least once during each membership year.......
I nominate @Dan Dubeau for his outstanding performance as the king of enablers. How many guys made or bought a belt grinder? How many 3D Printers? @JustaDB & @YYCHM are tied for 2nd place for their tag team performance finding deals and providing eye candy.
Double whammy. Between you and others (especially @CWret and @DavidR8), I bit the bullet too.
All of you are evil!!
I confess that I've been looking at a mag drill for quite a while. One day @CWret pointed out that they are designed to work with annular cutters and I lost all interest. My primary need is field repairs on farm equipment.
Then some greasy shifty member on here (prolly you @Janger) said that some models come with a drill chuck. The fire started burning again!
I ordered from Amazon and it arrived yesterday. Some comments are appropriate.
Look at this shipping crate.
Ya, it's not wood. But man is it nice! Total shocker.
Mine doesn't have discrete speeds. It's truly continuously variable. But unlike VFD variable speed, this one is not constant torque. So low speeds will die with any load. I believe that also means speed will have to be adjusted while drilling to stop it from stalling out. Nonetheless variable speed it is.
The drill chuck sucks. Visually horrible runout. But it has a flat register for the weldon adapter, so as long as the threads are properly centered, I can probably true it up on the lathe. We will see.
At first, I was really disappointed with the drill clearance. Barely enough to install the chuck.
However, on inspection, the drill motor is mounted on its own dovetail and can be adjusted for best clearance. After adjustment, the drill bit clearance is waaaay better than expected. With the drive head fully up, there is a full 5 inches to mount a drill under the chuck, and close to 7" when mounted in the chuck.
At first I was very disappointed with the magnet. It barely held its own with plain sheet metal. It was slightly better with 1/8 steel sheet metal. Mild attraction, but it works. So I tried a piece of 1/4 plate. Waaaay better but I can push it over with a bit of effort but not busting an artery. I also had a big piece of 1/2" plate. That worked awesome. I was not pushing that over even with my full 260 pounds on it. The manual says it needs 5/8 for optimum hold. So ya, 1/2 is good enough for my needs but it prolly does need 5/8 to reach full strength. I'm not gunna worry about that. As an aside, @CWret asked AI about mag drills and it suggested the max was achieved with 1" plate. That's actually possible with some of my farm equipment but 1" plate is not happening inside my shop.
In summary, I'm glad I finally bought one. So all you enablers are off the hook. This Time......
Oh good, so i am in the right place then....
I recently impulse bought this lad. It was on clearance when i was in the store, i had a gift card, and i'd just finished watching a guy i regularily watch on youtube use one to cut about 200 holes on a DIY steel shed he was building. I mean, what else could i do? The drill came with 2 chucks, the speed varies, and it stuck pretty solidly to 1/4 plate on my benchtop. And my dad already had a set of annular cutters.
Please tell me you didn't spend $900. My Vevor was on sale too, but it was only $230.
