Tool Vevor Drill Bit Sharpener
Tool
In my 13 A kit from Vevor only 3 of the smallest collets are this weird configuration. The rest are just regular ER 20 collets. Is this the same as what you guys got in yours???
I haven't opened all the collets yet but I assume that they'd only provide special collets where needed in order to save money
Well thats exactly where I was going. I was wondering if the special configuration was most important on the smaller sizes? Don't know why that would be the case but that would also be my guess.
Because regular ER collets for small diameters do not have a nominal hole size all the way through, they are counterbored. Without the 'enhancement' the drill would be flopping around in the air due to lack of support.
I think @gerritv is correct for the small ones. You need to get the ones that support the drill at the small end too.
But I think the bigger issue is at top end of the scale. That's where the ER25 holder raises its ugly head and where the collets themselves are VERY different. The are actually smaller and use a narrower clamping length.
In my mind, I may get the small collets just have them, but I have to ask myself if I will really ever sharpen teeny tiny drills. I could but 20 drills for the cost of the collet and that assumes I can even sharpen these tiny drills. At some point you just give up, buy a dozen drills, and don't worry about sharpening them.
it is the small ones I need to sharpen most... small models have small holes and small bits are prone to breakage in my hands.
Now that I have the cameron microdrill I hope to cure that ill
For the most part, I don't drill very many small holes very often. Mostly big ones for big equipment.
I'm very excited about what we might be able to accomplish with the Vevor with some effort. Sharpening endmills would actually be amazing if we can get that far!
I've been side tracked with personal matters and some home renos so no time for workshop stuff. But this thread is really tempting me to spend money on something I will never (rarely) have use for! :p
I have a set of hex head drill bits for my drill/driver, will they work in the ER collets?
The smallest hex head bit the DD will in the collet is a 3/16 at 2.5" in length, the smaller/shorter ones need to be done by hand.
Some of the hex heads I've replaced the bits and use a 4-40 set screw to secure in the hex holder. I may end up having to make all smaller bits replaceable to be able to use a sharpener.
TIA
I'd bet they will. The reverse setup of the collets leaves a fairly open volume at the back of the collet (the front of a normal collet). I don't see any reason that a hex shaft drill won't fit in there. But I have a fairly large set of hex shaft drills. I'll check the largest and smallest for you tomorrow.
There was talk about the longevity of these machines if you can't get spare grinding wheels in the future.
I was curious about the availability of the motors actually since they're a very rare bird that no vendor on aliexpress carries. I ended up contacting the manufacturer since I thought to build my own end mill grinder. They will sell the motors, but the shipping is not cheap.
Anyone want a spare, or one to build a grinder? $58 bucks
Count me in. Plus shipping to me of course.
