Tool Vevor Drill Bit Sharpener
Tool
I can put up a pic of the over sized er20 and er25 collets if it helps anyone. Have had em for the better part of 6 months I think. They are listed in my post about where to get em
Sure, I'd like to see them.
Different vendor from yours, and @Susquatch these are only 3 bucks shipping each, so you must have been referring to the vendor of the ER25 chuck.
The other vendor also different from yours doesnt have pics of the 1 and 2mm collets, but their shipping is free right now with purchase over 10 bucks
@Susquatch @TorontoBuilder ....show me the money!! Please sharpen a drill bit and let me see what it looks like, before any mods to the machines.
I'm a scientist. I live for data. I also do not rush when designing analytical methodologies.
Firstly, I'll buy 3 cheap princess auto drill bit sets typically found in a home shop. Ya'll know you got em.
One set will be kept aside to serve as the control sample with standard factory finish.
One set will provide the sample grinds for the unmodified 13B machine, as per the manufacturer's recommended settings.
One set will provide the sample grinds for the modified 13B to 13D conversion machine. This set will be ground to an optimized grind for each size of bit because there will not be a manufacturer's recommended setting.
The grinding sample sets will be in the following sizes; 2mm, 4mm, 6mm, 8mm and 10mm because 10mm is the largest bit in the set. This sample will require the use of the non-standard 2mm collet from outside vendor.
The modified 13D machine will use all newly machined custom parts so I haven't forever altered the original 13B grinder.
Close up photos of each sample set will be taken under the same work-holding and lighting set-ups for visual comparisons. The physical testing of the grinds will be conducted.
I'll rig a test wheel and weight to my standing drill press and compare the drill times to penetrate steel plates using the 3 different bit sample sets.
The drilled holes where large enough to visually inspect the hole will also be photo documented for comparison.
I'll solicit group feedback on a weighting matrix for evaluating each grinding set, but I'm sure it will be heavily weighted towards fastest drilling times.
Edit. I'll likely even conduct the 13D tests using wimpy less rigid 3D printed parts for chits and giggles. Then repeat when I have the metal parts all made
sentence-1: Then you will also appreciate the notion of garbage in = garbage out LOL.
sentence-2: That's exactly the route I went down thinking I cannot mess up bad drills anymore than they are. Well yes & no. It took me some futzing about to familiarize myself to my TCG setup & that's another story. But it only took a couple mm of grinding dust to get up to speed.
My 5C collet block fixture is pretty simple but dimensionally reliable. It holds a drill concentrically & terminates grinding DOC to a locked foot stop. Flip the block 180-deg & repeat. So why do some of these sh*tty Princess Tire drills have blatant unequal re-grinds on the primary facet? Some answers: banana axis vs straight. Elliptical cross section vs circular. Unequal flute relief profile so cutting edge is displaced. Not all, or to the same degree but enough that I'm just wasting my time. I put in a dull HSS Sears drill from the 70's & the point is damn near perfect first try. Its the proverbial sows ear. Sadly I can't even think of something to do with the crappy offshore drills to harvest the material. Having said that, I gambled on an inexpensive 2-10mm metric set of AliExpress drills for the house chores toolbox & turns out they are awesome. So they earned a spot on the drill press podium. The issue is you just can't tell by the picture or even so called feedback like "Look good, well packaged, came quick, will try them soon"
grinding crappy drills is really a test of the grinder's ability to deal with poorly manufactured bits.
I'm happy to test aliexpress cheapies if you have links to better bits that wont break the bank
I really don't think you need to grind more than a few to see what happens. The results should be obvious.
Unless you want to do it just to try and make them into decent drills.
We did that over in the other thread. (maybe we shouldn't have separated them.....)
And here is another photo of the final results taken from a different angle:
This last grind could be improved with a scooch of additional depth on the web thinning.
But I think the litmus test was drilling a few holes. They were amazing. No wander and beautiful cutting.
Ok. Thank you. I didn't see it on the other thread.
Looks good. I'll likely get one soon.
Ok it's late and some of those are terrible, will sort tomorrow
I think your photos are just fine. Now I know how they managed to do 20mm in an ER25. I just couldn't see it before.
Lots of new or copied ideas in that device. Some things are still a mystery to me, and many ah-so moments.
I tell yeah, based on the chinese sites and their available info it was hard to see how they got their claimed grinding ranges.
But at the very end of Stefan's duo grinding video he says the collet faces look funny, because the collet clamping is inverted and the sizing bore is located in the skinny end.
For instance, look at this 2mm collet:
look at the pointy end... and the projection
In my 13 A kit from Vevor only 3 of the smallest collets are this weird configuration. The rest are just regular ER 20 collets. Is this the same as what you guys got in yours???
