Irwin 27ZR 20R VISE-GRIP ORIGINAL 9″ Locking Chain Clamp​
Purchased it a number of years ago. Seldom use it but when needed it is a wonderful tool. I got the extension chain. Total length is 36".
Today, used it to remove a shower faucet that hasn't been removed in almost 25 years. The faucet had Teflon tape on the threads so it wasn't difficult to remove once I got it started. The problem was there wasn't enough room to get a pipe wrench on it (tub surround). Wrapped the faucet with a thin piece of tough rubber to protect the finish and then applied the chain clamp. Done.
Super easy, a 1 7/16" Powerfist wrench, $25, fits the lock bolts on the mills ram. Bought it yesterday and needed it today.
Bought these at Princess today on sale, of course:
I can think of several times I struggled to loosen/tighten a bolt with very little room to turn the wrench or ratchet. These might make a hard job easier. Not going to be the first socket drive I reach for but should get used occasionally. Pros are obviously stated. Cons are, according to reviews and based on what I see, little bulkier, not the the slickest reversing mechanism, and possible durability issues after repeated high torque applications (might go from 0 degree to no degree with enough force applied😀). Sale price makes it a chance worth taking IMO.
Some side-by-side comparison photos of the 1/4" Pro Point 0 degree model vs my 1/4" Stanley model:
0 degree Ratchet vs Stanley.jpg 0 degree Ratchet vs stanley2.jpg 0 degree Ratchet vs Stanley3.jpg
View attachment 78728 View attachment 78729 View attachment 78730
I have that same Stanley ratchet, or at least it's brother, and I find it doesn't "ratchet" very smoothly. I had an extension and socket on it, trying to start a bolt with my fingers on the extension, and it wouldn't "ratchet" to let me. Had to take the ratchet off, start the bolts, put the ratchet back on, tighten them. Not the end of the world, but you might find a ratchet with a finer tooth would make working in tight places easier, too. It's perfect for a truck tool, if it gets kicked in a snow bank I won't cry.
Or your PA ones might be the ticket too
Just checked Cranium Tire. They have a Maximum, 3 piece, 90 tooth, ratchet set for $59.00. Regular $130.00.
Edit:
- "0 degree" ratchet realistically needs about 1 degree of swing.
- Maximum brand 90 tooth needs about 4 degrees of swing.
I suspect the "clutch based roller bearing" design of the 0 degree ratchet is not going to be as robust as the geared Maximum 90 tooth ratchet.
I picked up a 3/8" drive, zero degree ratchet just like that from PA around a year ago, on sale. I don't expect it to be as robust as a regular ratchet, but I bought it because of the tight spots in engine compartments these days. Figgered it could be useful after the nut/bolt was already loosened.
Haven't actually used it yet...
I ordered a 1/4” Zero Degree from Amazon today l; I’ll let you know what I think when it arrives next week.
I also found these:
At US$185 - US$275 I assume they work very well. And “No,” I’m not going to buy one!
I also found these:
The ZeroDrive ratchet wrench looks similar in overall bulk as my Zero Degree/Pro Point wrenches. The way that guy in the video flicks the reverse mechanism with his finger to operate it is a game changer. I suppose it's overall better quality, too. But that price is crazy.
Super quality hardened steel jaws and teeth that are milled, like the ones ones on Knipex or Milwaukee 'water pump pliers'. The best thing before would be vise-grips, but if you just mill perfect sharp teeth, you don't need the pressure and can do the work instantly.
DRO's on both the mill and lathe. did the mill about 5 years ago. Glass scales on x and y, and the quill scale was the majority of the work, but the most highly used scale on the entire machine.
The lathe (12x36) was pretty easy. Just dont **** up and break any taps in the side of your lathe bed.
First upgrade to any machine tools should be digital readouts, assuming the machines are repeatable and good quality.
These really are a game changer. When you are conscripted to make 1000's of parts, you will be happy you have DRO's. Haha.
I have to mention my Hyperfit Porta-Band saw.
After years of sweating thru a few hacksaws I finally saw the benefits of a power saw.
Now it is a delight to setup the saw with its base and watch as it cuts thru steel bars like ‘butter’.
However basic, as far as operations, this saw is a relief to put in action !!
My 7x12 is probably the most used tool in the shop, (next to the garbage can).
This Powerfist brand 3/8" "flex head" ratchet is the hero of the tool box when it comes to automotive work. I was changing out the battery cable assemblies on my wife's vehicle today and once again it was the only tool that could get in position to do the job. The wrench head and socket just barely slide past all the lines and other obstacles but I got there.
I don't see this wrench for sale at Princess anymore but Canadian Tire and Home Depot sell a similar ratchet wrench with the extra long handle.
During this job I had a chance to use the recently purchased Pro Point 1/4" Zero turn ratchet (see post #644). A little different feel than a geared ratchet but it worked perfectly for what I needed.
These porta-bands are great! I mounted my old Porter & Cable porta-band on the wall and man it comes in handy!
Thanks for reminding me: I forgot to report when I received my 1/4" ZERO Degree "ratchet:"
As you noted, takes some getting used to the no-click (almost feels like its slipping, but it's not). The "Try Me" packaging is cute, but a little deceiving: the tick marks are about 5-1/2° and if you swing from stop-to-stop you move the arrow about 9° (40 swings for a full 360°). It's actually hard to only move the handle 1°, but by being careful I have been able to get movement resulting in about 1-1/2°.
And I also agree with the comments about the reversing knob – a little stiffer than my 1980's Craftsman 1/4", but not a deal breaker.
The only real problem is deciding which tool box to put it in: Garage? Shop? Specialty Box for a specific purpose? Buy 3 or 4 more and have one everywhere? (Gee, I hope it doesn't come to that!) Prices on Amazon range from US$22.73 to US$30.97 (I paid US$22.53 22 days ago).
