For my birthday when I was about 15, I asked for nut drivers and was rewarded with the color coded Xcelite set. I have been using them ever since, great set.
More recently I picked up a Wera metric set.
No tool junkie should be without 😉
Do you find the Xcelite drivers smell like puke? We have them all over work, in almost every toolbox and they all smell like vomit. It's effing weird
No smell. I also have 5 of the mini/stuby sets; nutdrivers, Allen drives, screwdrivers etc. none of them smell, but they are all most likely decades old. The small sets are in a drawer at my electronics bench where I use them all the time.
Slonik – 1000 Lumen LED USB Rechargeable Headlight
Mostly for automotive work but I have found other opportunities to use it.
Very comfortable and adjustable. Much superior to other headlamps I've used. So much better I went from disliking a headlamp to can't imagine doing certain jobs without it.
Slonik Headlamp
findmall 10 Ton Hydraulic Wire Terminal Crimper with 9 Dies & Cable Cutter for 1/8" to 3/16" Stainless Steel Cable Railing Fittings https://a.co/d/ckxT6bE
Way easier than the one shots. Made up some gate cross braces and lanyards for tools quick and easy.
Diamond whetstone 300/1000 grit. Why didn't I get one of these long ago? I printed some angles 15,20,25 degrees as guides. Kitchen knives are much sharper now.
You just use water, and an eraser cleans it up after. I don't think you can wear a dish shape into it. The instructions claim they are much more abrasive than stones and hence faster. I'm a noob at this so I don't know any better. Anyone have those chisel or other tool angle jigs for use on a stone?
You just use water, and an eraser cleans it up after. I don't think you can wear a dish shape into it. Anyone have those chisel or other tool angle jigs for use on a stone?
How do you use the angle with a kitchen knife?
No, I just put it there on the angle to start. you can see the elastic band holding in place. But maybe a wide version with some sort of attachment to the knife could work. magnets?
So the edge of the blade runs on the same spot of the stone? Trying to get my head around this.
Hi Guys,
There is a plastic gadget that clips onto the back of a knife blade and holds the blade at about 15 degrees to the stone.
I recently purchased four water stones from Lidl here in the UK, one 400 grit, one 800 grit and one 1000 grit the other 1200 grit. A total of £12.00p. The plastic blade holder comes with each of the stones.
Slonik Headlamp
I’m surprised they passed safety inspection without turn signals on the side.
Slonik Headlamp
There's a handful of techs who have something similar at work...freakishly bright and mildly annoying when they forget its on and walk in to the parts room and high beam a guy
I've got one of the flexible band types and I love it.
Best if kept on low power tho...the bright level tends to make it run hot and your forehead gets all sweaty lol
I use mine A LOT. Takes a lot of the frustration out of some jobs where getting good light on the subject is essential. And yes, I am one those guys who often forgets that I have it "ON" and sometimes blast people in the face.😎
I bought a package of 3 of similar from Costco for $23 cdn...one of the best purchases Ive ever made I use one daily when working on projects . The headbands are super comfortable for long periods. Some are not directional but mine are $ that makes them very efficient...no more needing someone to "hold that fcn light here not over there". I can direct it where ever I need it myself
The important thing is USB rechargeable. The three AAA battery units are nothing but a PITA and a costly one at that. A couple of months ago I found my old Tikka Petzl on the floor in a storage building where I had dropped it years ago. Took it home and plugged it in and it's working as good as ever.
The older Petzls had a sliding diffuser screen you could flip up and down over the lens which did a good job of spreading the light and protecting the lens. It also remembers which setting you were using when you turned it off so a quick press gets you back there. Red for night vision preservation, two strengths of of white, flashing white and flashing red, all with simple sequential button presses. The only weakness was the housing where you open it to recharge, but electrical tape takes care of that now.
