Here is the ST chuck & test setup. After 3 days still attached to spindle it hasn't moved a tenth.
Chuck is forged steel & I believe backplate adapter is the same.
Bison 5C Set Tru Collet Chuck
www.ajaxtoolsupply.com
Yes I always find the best D1 pin orientation if there is one & repeat installation that way for all my chucks
You can tighten a cam-lock spindle like a tire. it works fine. I was taught to go around 3 times, lightly, firmly, and then fully. then it does not matter - the chuck should be evenly drawn to the axial seat using either technique.
Just happened to be YouTube grazing Stefan for another content purpose & this caught my attention (~10:00 and again at 31:56). Obviously he is dialing it in which we all know about. But maybe my 'set-and-forget' notion is completely misguided & not what these chucks are all about. Maybe the whole idea is you have the capability to tweak them in to very close runout no different than an independent jaw chuck? Whereas with a non-adjustable chuck or collet, thats kind of the end of the trail without some other form of fix, either temporary or permanent.
Actually there are: you can see them in this screen grab.There are no clamping screws on that chuck that I could see.
In a previous video, he goes through how he built the backing plate & and how to use the Zentra ST 6J. (indicating starts @ 23:30). He does not back-off the opposing set screw while setting in this video; he does, however, in the one @PeterT linked above and others where he uses the chuck.
Agreed 100%. I go as far as tapping the individual jaws of the 4J with a soft blow after the part is centered. More often than not the part moved as the forces equalized on the jaws. Nip them up again to re-center - good to go. I only do that when it really needs to be tight tolerances.I think anybody who does a lot of work centering and/or alignment has their own feel for when to do it and when to tighten a scootch more instead. I certainly do. It's an experienced feel sorta thing. Sometimes I do and sometimes I don't. Therefore I can hardly hold his inconsistency against him.
If you give it some though, if you do not have EXACTLY the same size part, and EXACTLY the same tightening sequence and torque, there ARE going to be differences! Ever looked at the scroll in a chuck up close? They don't put near as much 'Precise' in to them, as folks would like to think, but, on average, they offer pretty usable accuracy! The truly tiny changes, are almost always just tweaks of the level of torque on one adjuster or another. <shrug> if ya wanna run with the big dogs, ya gotta get off the porch! 🙂 I would say that anyone that thought they could buy their way past having to go through the 'four-jaw' adjustment each time, really didn't understand how reality works in machine shops. When you can afford the amount of difference introduced on a regular 3 jaw chuck (usually some part that can be made entire in a single setup of oversized bar), it is the fastest cheapest way to an end. If you NEED concentricity when the part comes out of the chuck even once, then you must expect to have to dial it back in, each and every time. IMO, the adjusters simply reduce the amount you have to adjust, while still making it more convenient than a 4 jaw, they do not cancel the need to adjust the final runout to what is acceptable!Hey @PeterT - I have spent about as much time as I feel is reasonable on this issue. It seems that there are both chuck manufacturers and chuck users who call some chucks Set-Tru and some chucks Adjust-Tru. But then 90% go ahead and describe the process like it is set and forget. But 1 in 10 or so (like Gotteswinter) tend to use them as an ongoing adjustment made on a regular a lm st routine basis.
I think we all use our tools the way we learned, or were told, or feel comfortable. Why should a set true system be any different?
That doesn't address your root question though. I still have no idea why yours would drift just sitting on the shelf. But maybe if you stick to using it the way Stephan and 10% of other users do, then it doesn't really matter.
Or just maybe, there really is an Adjust-Tru and a Set-Tru difference that has been lost in the dust of popularity.
I've always wanted a 6 jaw chuck anyway, so I've added a Set-Tru version to my tooling wanted list. Maybe Santa will treat me nice one of these years or KBC will have a close-out sale. How do you like yours? Do you ever wish it was bigger or smaller? (I can't imagine ever getting two...... LOL! )
I like my Bison 6" ST reversible jaw chuck. Depending on your work, its maybe a nice-to-have vs need-to-have. But its the right size for what I do & my 14x40.
More jaw contact means more secure grip & kinder to delicate parts, of which model engines have of. Or say work like nice fly fishing reels we have seen. Caution @eotrfish is a 6J Enabler haha.
For some parts on the radial I had to machine dedicated fixtures that the 6J would have held. Be aware that 6J minimum holding diameter is a bit less than most 3J chucks but usually for me that's collet territory anyway.
The issue that kept me on the sidelines for many years was COST. They really went through the roof past couple years since I bought mine. I saved a lot by going through USA distributer, so shop around. Remember to confirm that price includes the ST backplate which is spendy by itself. Other $reduction options could be a 5" vs 6" or another brand such as Gator. Maybe even Shars with some tuning work a/p Renzetti but I'm on unchartered waters there.
