Thread indicator
glenhw
I just picked up a myford ml7 but it had a no thread indicator so i started building one cut the gear today my fist atemt at one ground a single point cutter and mounted in a piece of 1/2 in stock
I think it turned out ok
I drilled and tapped a 1/4 20 hole in the end of a 1/2 in stainless rod then milled a flat spot and drilled a hole through to take the cutter
Not sure if this is the best way but i dont have invalute cutters yet
Not perfect but seems to turn on the lead screw nicely
Well done! How did you dish the top of the teeth?
I'll be watching this thread.....
Beauty! Well done!
Do you have a set of plans or drawing showing how to time this threading indicator?
What is the tpi of the myford leadscrew? My Southbend is 8tpi. If yours is the same I can find the instructions. The SB uses a 32 tooth gear but conceptually they would work with a 16 tooth gear.
8tpi i went with 16 just because that what the factory one is
