I have often seen where the snow has melted back from a footing/foundation from heat inside a building, concrete has a very low “R” value as does glass and steel, aluminum is worse. If you can put insulation down a wall/foundation 3ft. it seems to stop most heat, but can depend how far frost goes down.
A heat scan taken inside, of concrete walls, floors, can be a real eye opener. Of course this is much more revealing in the winter time, and for some what the @#$& moments go out side and see where the heat is really coming out. Windows, uninsulated doors, badly sealed doors, vents, and heater chimneys, and of course the “ what happened there spots, I guess I must’ve missed that one”
We also scanned our electrical panels, wiring, motors, at work, this was a bit pricey the first time, but did reveal a few loose connections, a failing contractor, and one pump motor running slightly hotter than another ( didn’t find a reason for that), anything found was checked, repaired, replaced, and rescanned. This equipment was put on an every other year scan from then on. New equipment to be scanned as when possible.
Ops, did I say squirrel ?
