Product Shop vac filters
Product
I'm thinking of redesigning this as a round tube so I can have a clear acrylic body to see the mechanism in operation.... to aid in adjusting the force of the snap and de-caking operation.
I just bag mine out as well, then blast some air at the inside of it. I like the idea of the Amazon ones PeterT, would never go to HD for that stuff.
My process exactly. In this case its $16.68 from Ali including (happens to be free) shipping or $14.87 next day delivery from Amazon prime, presuming comparable item. Sometimes it works out this way, usually Ali is cheaper.
My point is to not give any money to a US company if avoidable. Plus the tariff money going to their government. AliExpress shipping is less than 2 weeks now.
Sometimes you just have to play with such ideas to see how they work and how to improve them. The so called proof of concept and development process.
If (a very big if) there is a flaw in the idea, I suspect it is in the inertia of the vacuum system airflow and the blower fan. The combination of these two factors may not allow for the rapid release you envision. You may need some kind of mechanism that changes the release speed vs the apply speed like a shaper does, or a triggered system that traps vacuum and then releases it suddenly.
Of course, the only real way to find out is to build a testing prototype and test it!
Are you really allowed to have that much fun? My bride is sick and tired of me experimenting with stuff on "our" nickel. She would insist I just buy extra filters from Ali.
I expect that in order to get the rapid release the vacuum motor has to brake rapidly.... the spring has about ~15 pounds of force, depending on how much it will be compressed in operation.
But no matter, my design has a minor tweak to make it manually operated just in case.
What I want to see is the static pressure and velocity drop from different filter media with the same area of filter material.
I'll sacrifice some filter efficiency to maintain higher flows if necessary.
I didnt know auto filter cleaning was a thing. Apparently Bosch has a system. Not sure how I feel about an occassional Bang, my brain goes into autopilot, Bang = Bad 😱
What I thought would be a good idea is a timed vacuum like suck every 5 seconds like vacating chips in a pocket or on a scroll saw vs having the vac going full bore in the background. Thats probably required for lots of woodworking equipment, saws, sanders, routers... making constant dust/shavings. Pulsed blowing is easier because its just opening a valve to a compressor tank, but then you just have to deal wherever it blew the chips to, probably including your hands your eyes... So with a vacuum either you are turning the motor on & off which is not condusive to long life or you need some kind of vacuum chamber which is yet another clunky vessel. Probably why nothing exists outside of the dentist & medical equipment, Eeuuuw
I heard that festool had self cleaning but didn't know how they implemented it. I see Bosch now has it too... but the manner that they have looks like a recipe for high failure rates...
My use is always limited and it will only clean every time I turn off the vacuum when Im done.
Festool and bosch are designed for systems without cyclone ahead of the vacuum.... because they want to charge $1500 for a vacuum cleaner.
I grew up without flourine so my teeth are horrible.
I don't care for freezing so normally I just let them drill away without freezing. Sometimes I even fall asleep in the chair. A root canal they did a few years ago that went south caused me to reconsider that practice. I've had a few involuntary tooth extractions that were not frozen over the years so extractions are ok - until they aren't. When it comes to colonoscopies, I prefer to not remember anything.
I changed the design...
Dual action. Shakes the frame on start up and stopping, and then has a manual actuator just in case... so I wont need to modify if the desired action does not work.
I converted it to a cylinder, and added a segment of polycarbonate to see inside, cause why not?
I added a filter frame to help keep the shape. I will use a new pattern with more open area though I think...
1 spring. I will make the upper plug deeper since it is also a guide for the plunger rod. I'll make the upward motion stop thinner.
I would prefer to support the USA instead of China
That's going to get me a political time out
I will never support anything Chinese
Cool project John. I’ll be following along…
Imagine if I has a disposable slip over sock filter made in the same way they make N95 masks... Hell if there was a place I could buy assembled material I'd make my own jigs to line everything up and then seal with a modified heated leather creaser.
I was supposed to go to guelph yesterday and today to pick up the 3D printer, but I have flare up and felt too crappy to spend 5-6 hours on the 401 both days
Anyone with light woodworking have issues with dust specifically related to desktop computer or 3D printer in the same space?
I don't intend to do much regular woodworking or anything but concerned my computer and 3D printer might not survive if I relocate them from the basement into the new workshop. I assemble my own computers with components from scratch and bought all very meshy/open cases so thinking the dust may cause some issues. I won't do enough woodworking (or space) to warrant any dedicated full out air system, and will do the shop vac/dust deputy approach mentioned here.
I have a laptop in my all purpose shop and the only thing I do is blow out the keyboard every once a while.
Hmmm the intake and exhaust ports of a laptop are much smaller so I'm not so concern there. Perhaps that's the safest that I also just keep to a mini-pc/laptop in the workshop instead of a meshy full computer case.
