A friend of ours has taken up jewellery making and I remembered somewhere in my boxes of stuff I have an old rock tumbler that my mother used when she was into it. I found it, pulled it out and realized why we'd never done anything with it.
Seems the drum that holds the rocks and abrasive was missing.
No problem. I have a 3D printer. A bit or research online and I found this one. A lid for each end. So it rides on the drive shaft on the outer part.
Didn't work well. Slipped with so little in contact with the long shaft. So I put some rubber around it. Better but as soon as I out rocks in it the drum just sat there.
So I designed my own.
Works much better but still slips a lot. Even after smoothing out the bumps from the 3D printing.
The problem is the drive shaft and idler are actually a steel shaft covered in a plastic tube. The plastic has hardened over time which isn't surprising given that it's likely 40 years old.
Looking for suggestions on what time of hose or tubing to use that would improve on what is currently there.
