RF45 too good to be true!
MrWhoopee
Active Member
Says package weight is 1kg 1cmx1cmx1cm
and at the end of its title it says micro small. So you may get a package, but it wont be what you hope. Maybe its an RF45 keychain
I was going to say that I wished they had a dollar bill next to it for scale, but the dimensions given for the machine look reasonable.
Darren
Touch DRO is $410 for a fully assembled adapter, then I'd need a tablet, and scales, no?
Maybe for the next one, but at the time it was easier to just order a package and focus on other stuff.
DavidR8
Scrap maker
I bought an unassembled kit for $180, put it together in 45 minutes, bought a used Amazon Fire tablet for $50 and three mag scales for $250.
All in I spent under $500
At that price, I'm interested. Where did you get the mag scales?
I am just finalizing an Ali purchase of the Ditron DRO package for my Lathe. It's the end of the 1st qtr so they should be hungry. Maybe not as good as I could do at the end of the year, but I can't wait that long. I want to put the system on at the same time as I install a 3ph motor and VFD.
I have a Ditron on my Mill, and after a lot of soul searching, I think it's best for an old man like me to have everything work the same. That way I don't have to do things differently. The interface will be the same. To me, that advantage is worth the difference in cost.
I've spent a fair bit of time evaluating the Touch system and I like it a lot. But I can't really see any compelling reasons to go that way.
I should add that one could always just move the tablet from one machine to the other and save on that cost too. Alternatively, I could just add the touch box and a tablet to my mill so both could be the same.
But again, it not like the Ditron is junk or inferior to the touch in any significant way. It's a gorgeous system that works extremely well.
If I were starting over, I might go touch. But that's a different debate.
I'm posting here to get notifications of updates.
Looking forward to news on both orders!
That's an interesting way to be able to follow different discussions. I maintain a link list for that purpose. I think I like your way better. But it makes me wonder if there isn't a system method that is even easier yet.
Edit - THERE IS! At the very top of the thread above the first post there is a watch / unwatch button! My list just died.
That said, your way allows you to let other thread participants know that you are interested in their discussion which has significant value too.
gerritv
Gerrit
In Sep 2022 when Darren order his DRO kit the TouchDRO was still in no-updates-for-known-faults for 3 years. So he made a good choice on the purchase IMO.
I am sticking with Aikron, because I already have that on my lathe.
gerrit
DavidR8
Scrap maker
gerrit
Whoops I missed that date. I thought that he ordered it at the same time as the mill.
Darren
I recall there being an issue with lost positions if the movement was too fast? Either way, I like the Ditron system. I already had it on my Emco.
What does the touch dro do differently? Can you link me to the scales you bought @DavidR8 ? I need a 65ish long scale and the prices i'm seeing are more than you'd pay for a complete milling machine these days...
DavidR8
Scrap maker
This is where I got my scales.
I'm a big fan of the display on the TouchDRO. Likewise how it functions when doing things like bolt circles because the display shows you where you are in relation to where you need to be.
Check out the TouchDRO channel on YT.
wow. So I did a search on Ali thinking about my big lathe. I found this: gosh I don't need another project, but I'm tempted! (US$)
that's enough tape to Z and Y, and anoterh 50$ gets a second reader. Jim Dawson on the other forum recommends buying tape and doing it yourself for lathe installs. He says it is the same work, often with comperable or better results with much less cost....
DavidR8
Scrap maker
Mag scales are stupid cheap right now.
That said, on a lathe Z axis I'd use a glass scale for ease of installation. Drill and tap two holes and the scale is on. If your carriage has provisions for a taper attachment there may even be drilled and tapped holes that could be used for the read head mounting.
