Yes I forgot to mention that there is likely a channel on the underneath that I could just drill up from the bottom to make sure I get in it. I've had it all apart but I just don't remember exactly what it looked like underneath there.In my experience with oil holes they are sometimes located to feed into a channel or line that takes oil to where it is required. I would take it apart and see how it is constructed.
I think that may have been an option (certainly was with other suppliers) but I have already purchased this DRO 6+months ago and so am going to make it work. I'm just contemplating all the options now.Does the DRO manufacturer offer a slim magnetic scale?
If you are going to drill I would be taking it apart and to check it can be done and to prevent swarf from getting into the lubrication system. Cast iron is nasty stuff.Yes I forgot to mention that there is likely a channel on the underneath that I could just drill up from the bottom to make sure I get in it. I've had it all apart but I just don't remember exactly what it looked like underneath there.
I'm going to be installing a DRO on a lathecross slide but the way I think the scale should be mounted blocks an oiler port. Drilling a new hole in the saddle and popping in a new oiler port in a different location shouldn't be a big deal right? I'll just plug the old hole.
It looks like your gib strip is right at the bottom surface of the cross slide. If you remove that gib adjusting screw you'll see how tall it is and drill your screw holes above it. I agree with the others, I would remove the cross slide to drill the new oiler hole. You really don't need to make a plug for the old one, just leave it where it is. I made 3/8" thick spacers to move the cross slide scale outward so I could access the lock screw with an open end wrench. I added a brass insert to the end of the screw and made it just long enough to lock the cross slide when fully threaded in.Dang it you guys! Don't go convincing me I need to buy new scales, it can't happen.
Just because I am not willing to follow your advice doesn't mean I don't value it. I do value all the advice immensely.
The slim scale solution would definitely easily solve the oiler port problem but I think I'm going to be okay afterall but it will be close. I also have to mount the scale away from the cross slide surface to allow access to the slide lock. Traveling rest mount on the carriage keeps me from installing the scale on the opposite side (plus I don't want scale under the chuck).
My next obstacle is mounting the scale brackets into the slide surface as their is very little meat to drill and tap into as the gib adjustment runs along that side. See pic.View attachment 27618
So now I'm wondering if JB welding mounts to the slide surface is likely to be satisfactory?
My first feelings about JB welding attachment is well, "it's sort of Mickey Mouse-ish" but I haven't been able to completely rule it out yet.I would not recommend adhesive for any kind of DRO mounting unless you mean to temporarily attach so you can better drill/tap holes or back fill a slight unconformity. Its better to bolt it together mechanically. Odds are you may have to dismantle lathe/DRO in the future for whatever reason & then whacking off glued parts wont be fun.
I showed some pics of my scale on LHS of cross slide to avoid gib strip. If you protect it properly with a guard, its not a big deal. But you might lose the functionality of mounting a travelling steady so there are pros & cons that only you can answer for yourself. Do you have a table lock on the RHS that the scale will cover up for example?
I would only glue the one side of the bracket to the slide surface, so if I ever had to dismantle it would not be a big deal.Odds are you may have to dismantle lathe/DRO in the future for whatever reason & then whacking off glued parts wont be fun.
Yes I have a table lock on the rhs, but I should be able to get the scale in just before the two obstacles. But i wont be able to have the cover over the scale. And no I don't want to loose the ability to use a steady rest on the front side. At least that's my latest thinking. See pic.Do you have a table lock on the RHS that the scale will cover up for example?
Yes that is pretty much what I was thinking also in regards to accessing the table lock also.It looks like your gib strip is right at the bottom surface of the cross slide. If you remove that gib adjusting screw you'll see how tall it is and drill your screw holes above it. I agree with the others, I would remove the cross slide to drill the new oiler hole. You really don't need to make a plug for the old one, just leave it where it is. I made 3/8" thick spacers to move the cross slide scale outward so I could access the lock screw with an open end wrench. I added a brass insert to the end of the screw and made it just long enough to lock the cross slide when fully threaded in.
FWIW. I never suggested gluing the scale extrusion, just the mounting brackets that the extrusion will bolt onto.But I agree, I'm not in favour of gluing the scale extrusion to anything on a permanent basis.
Well who knows when I will finish this job as it's kind of low priority. I had no idea when I got out of bed this morning that I would be starting this project today. It was a "diversion" project for the day to forget about some of lifes real problems.So I gather you are gunna make me go first...... I forsee a drop dead gorgeous cross-slide scale install. I'll send you a PM when it's done so you can cry..... LOL! Might be a while though!
