Refurb my Atlas
Finished the epoxy repair on the cross feed gear that needed a key. I used a hacksaw blade to saw grooves on each side of what remained of the key, then pressed in some Loctite epoxy, then filed for ever to size. Looks to me that it may work for a while. ......................................Daniel
Now is a learning curve, grinding tool bits is just one.........
Ya, and using a lantern rocker style tool post doesn't help. I used one for 45 years or so. I think the most important thing to remember is that all those fancy grinding angles have to be from the lathe spindle's perspective. You have to learn to move the tool post and tool holder into the background of the picture. The angles only matter from the point of view of the spindle.
Yup, first job is boring a brass bushing for my cross slide gear. I got a tool ground that seems to be working well without a boring bar.....................Daniel
