Onan Generators
When I was working, I would often think, I can’t believe I’m being paid for this, it’s so interesting and just plain fun. Other than a short spell for a crown corporation most of the people I worked with were performers and great to work with. When I didn’t like the “chemistry” of a place I just skedaddled out of there, life is too short for that nonsense. Some environments are definitely toxic, however in most cases you have a choice.
Yeah, I always had a choice. The saying that surrounded that choice was "Press hard, you are making seven copies", referring to the Release Request form that the Forces used.
Liked the work, liked at least many of the co-workers, thought a fair few of my bosses would better serve humanity if we parted them out and used their organs in someone more worthy...
The bosses I had that were really competent and capable leaders, were a pleasure to work for and as often as not, simply highlighted just how poor the bad ones were. One of the sure things in the CF, was that if you were not moved along, the person getting under your skin, would be, eventually, so your contact times were always going to be limited, at least to an extent.
So how did you end up as the point man on that assignment?
The classic line-up of volunteers and everyone took a step back but you?
Or was it your responsibility to handle PR?
You are a sharp cookie.
I was away on business when the meeting to decide how to handle it was held. Apparently, the decision to nominate me was unanimous.......
Geez, man! That job usually goes to the guy that was not at the meeting to defend himself from it! 😛
eing interviewed by CBC Marketplace as a corporate villain was a definite one time event I'd like to forget. Even if I never do it again, it will be waaaay too soon......
CBC---Communist Broadcast Corp. The wife was unviewed at a firearms rally before C68 became law ...They edited that interview to be exactly opposite of what she actually said when it was broadcast....Fcn liars, the works of them
The CBC used to be fantastic back in the 70’s-80’s. Interesting discussions about world events. I can’t listen to the modern rendition, completely unrecogniable.
That's exactly what happened.
But since you guys insist on picking at this open sore of mine, I'll add another chapter to the story.
I am pretty sure I would have been picked even if I would have been at the meeting to defend myself. I tried to call the whole thing off as a dumb idea to even agree to do it. As I put it to our PR guy, "You can't win a pissing contest with a skunk". He laughed about that but then he looked at me and said this:
Nobody expects you to win. Your job is to minimize the losses. We have reviewed what happens when companies agree to be interviewed vs what happens when they don't. When they don't, they get slaughtered. But when they do, they still lose, but it is possible to minimize those losses. That is your job. Besides, I talked to our CEO and we all agreed that you were best equipped to do this. We will all be behind you and we will do our best to help. ( Ya right... Sure you will.... You are not the ones getting hung out to dry on national TV! )
CBC also went after Bell telephone that day. They didn't show up and got slaughtered. Lots of people all across Canada saw that show. Those I talked to who knew me or recognized me all told me that I came across pretty well. Perhaps they compared me to Bell. I don't know.
All I really know is that I hated almost every second of it. In fact, the only real fun I had, I got shit for. The journalist kept asking me the same question over and over and over. I gave the same answer over and over and over. I think she expected me to say something dumb at least once. Didn't happen. On the last try the tv camera was to our side and only saw my left side. When she asked me again, I winked at her with my right eye as I repeated my response. She totally completely lost it. Of course her hissy fit didn't make the cut. But she didn't ask that question again. In fact, the whole thing changed into more of a regular interview after that. Our PR guy had to give me shit for that stunt cuz it could have blown up in my face, but secretly I think he really liked it.
I spend a fair bit of time working on Onan generators; you need a way to measure the frequency of the power it is generating to check the engine speed first. Then, once you have a steady 61 hertz unloaded, you can move on to the electronics. Sure, parts are a bit expensive, but they rarely need parts unless a catastrophe happens. Ideally, your engine should be at the rated rpm, which you set with your clamp meter or multimeter. Then, open up your wiring diagram and start testing individual circuits and components. There is a forum called SmokStak where a lot of knowledge is held.
Frequency is very close and is purely mechanical (governor) . There is a notched slot that a springy shaft sits in, and it looks like the intent is if you want to tweak the frequency, you move to the next notch, I might play with that a bit just to get a feel for it.
The newer fancier model has fuel injection so they can control the frequency via subtle throttle adjustments, on mine it's throttle on or throttle off period, the governor controls the speed and the control box controls the output voltage.
Hardie board enclosure is about 1/3 built.
Goal is near pushbutton back-up power when the lights go out, no wheeling generators around, just plug and play.
Cost so far:
Generator: Free
Parts for control module: $1.41, but had one in my stash so free
Outboard motor tank: $25
Hardie board: $125
TOTAL: $150
If all goes well should be about $200 all in for 7kW of quiet power ;-)
October 1969.
ARPANET
Arpanet was not open to the public. It was military and approved researchers only.
Compuserve started a closed system of dial-up service at roughly the same time. I was one of the first 100 users. I had to dial in to Chicago from Windsor. My first use of the internet was in 1979.
The transition to public ISP based internet occurred in stages between 1989 and 1995, driven by three key developments: the emergence of commercial Internet Service Providers (ISPs), the removal of government restrictions on commercial and public traffic, and the creation of user-friendly web browsers.
