I got the Buell forks and triple clamps modified for the XS650. The Buell steering stem is about 1" too short so I pressed the original steering stem out of the lower triple clamp. I ordered some retrofit steering head bearings from All Balls with 48mm OD and one with 27mm and the other 30MM ID. The 48mm OD will fit the XS frame and the ID's will fit the custom steering stem I am machining. This pic show the original stem and the custom one I made along with the 2 bearings. I machined the stem to have a .002" interference fit into the lower triple clamp but I threaded the ID to 5/8" NF to assure it can't slip off. The lower inner bearing is a .0005" interference fit to the stem and the upper is a snug finger press fit. The upper triple clamp is a .001" interference fit onto the stem.
The Buell stem was originally held to the triple with a press fit and a snap ring. I feel safer with a bolt holding it on.
The outer races fit the frame perfectly.
The upper end of the stem is threaded to 5/8" NF as was the original Buell stem.
There is some interference between the upper triple clamp and the front of the gas tank. I used some 1/4" bolts threaded into the bottom of the upper triple clamp to form steering stops and will have to move the gas tank mounts rearward 1/2".
It has about the same amount of steering lock as my Buell.
