Hey John,I'm waiting for a couple of seals for the top end of the engine so I went to work on the tank and seat. I had previously moved the front tank mounts 1/2" back so I made up a new rear mount post for it. I just drilled the hole for it half and inch back from the original. The original was welded to the frame, this one is held onto the frame with a nut.
I found a vendor on eBay that sells reproduction seats for Yamaha enduro's and after some measuring I ordered one for a DT175. I thought about narrowing and shortening the original seat and getting a custom foam and cover made but that would have cost more than this seat did. I made up 6 mounting pads for the rubber cushions of the seat and fabricated a couple of hold down straps. I had to weld those 8 pieces to the frame so I chopped off the center stand mounts from the frame while I had it stripped down for the welding. The seat is thickly padded and nice and narrow and seems to be high quality and I like how it looks on the bike.
I finally got around to removing the brake caliper mount from the left fork leg to clean up the look of the fork.
This is how is sits right now. After I get the engine together it will get a final mock-up assembly then be disassembled for paint. I haven't decided on a color yet.
Nice work on your bike projects. You wouldn't be interested in an old Yamaha CT for parts or a project itself would you?
Don
