Brent H
@Susquatch - if you are looking at the spindle and it it turning the cutting edge would travel from right to left - if that makes sense - if you were staring at the draw bar from the top it would be rotating clockwise - you would lock the spindle and turn the draw bar counter clockwise to loosen the collet.
Does that make sense? Really you just want to spin the spindle so that the pulley plates can come back to where they should be with reference to the position of the speed change plate.
Basically that rotary dial on the head tightens or loosens on a chain that is connected to the speed change plate. That plate pulls down or eases off on a spring return pulley half. The pulley half opens or closes forcing the drive belt out or allows it in to effectively change the diameter of the pulley with respect to the motor pulley. The motor pulley travels up and down the motor shaft to keep the belt aligned properly.
I have been looking for some pictures of when I had my mill apart but seem to only be finding shots of smoking meat and drinking beer by the pool ....summer fantasy ? not sure but no mill head pics for some reason....alas.
It is my hope that if you can turn the mill by hand the belt may return to where is normally would be with the reference to the speed control position.
Normally, if you are changing the belt - or want to remove the motor you can dial the speed control to the fastest speed and this will open up the driven pulley and take as much tension off the belt as possible.
If you take off the cover plate to the speed control (two small slot screws_ behind that is 4 allen head screws at will take the speed control off. The speed control should be linked to the speed control plate by a chain and this wee chain will have a turn on the speed control spindle. This assembly is all together and should not come apart on you. Issues that could exist is that the chain is off (10), one of the retaining pins missing (9 and 9a) ? The worm gear (30) is not pinned (15)
You will be able to see inside the head at this point and you can check if the belt is all proper and the pulleys are correct. - if one of the motor drive pulleys is stuck or the speed selector plate is not connected or something is missing to allow the selector plate to operate correctly.
