New thread 3D Printing
Hi All - I think we should have a new CNC forum for 3D printing. So here it is! Any comments on the thread itself put them here. Start new threads to discuss 3D printers, techniques, etc.
Tom O
You could but there is way more 3D printers out there I’m just wondering if the site would be overwhelmed and steered off course!
Bofobo
M,Mizera(BOFOBO)
Im positive that this is a cross over medium, cnc steel printers are already using the same tech, built on a foundation of cnc programing widely used in metal fabrication and cnc machines. If i can get a grasp of the tech i would build a fluxcore printer, because why not!?
kevin.decelles
But as a prototyping medium, Gcode tutor etc it is an indispensable part of my shop now. If I can only get time to perform some lost wax casting...........
Here is my ford boy making a really fancy aluminium part by casting from 3D printed lost wax process. Pretty neat stuff. My spouse was asking why did he need to fool around with all that piping through the sand. Why not just fill up the mold with aluminium to the top? I mean just fill the white investment cast mold?
Tom O
I tried using some plaster and sand for a casting once after drying in the kiln they become quite brittle. I used a printed mold and that microwaveable material from PMS Hobbies you just heat it and pour giving you a rubbery pattern although it is flexible but could be strengthened with wire in the cavity or cooled in the fridge.
Tom O
Are we talking about using the centrifuge type of casting? I have been toying with the idea of building one for my Sons wife and Daughter.
Johnwa
I think 3D discussions on this group should center around mold making, casting, and of course making any accessories /holders that we use in metal working.
There is a Calgary 3D Facebook group. They seem to be fairly active with monthly(?) meet ups.
Johnwa
Adding the top of the mold and the can on the top increases the hydrostatic pressure which helps to fill the mold.
kevin.decelles
I mostly print parts as models for sand casting but have also replaced parts on my equipment including the pulleys on my cnc mill
Alexander
How long did it take to print that?
42 hours. Allot of time was spent printing the supports that were needed for the top. I think I could have printed it upside-down and saved 10 hours but then it wouldn't look as nice from the front.
Tom Kitta
So since I have lots of people that have printers is this is a good thread to ask for suggestions about a FDM printer purchase? I was thinking about more basic model up to say $500 but fully functional, not a kit, just something that will do some prototyping and look decent. There seems to be a lot of choices - is there a trustworthy site comparing the models?
My research of resin vs. FDM show that resin is around 3x more expensive to run then FDM but in the same printer class produces a bit better resolution. Through the main "shine" area is use of resin that is "special" - for example - one that is resistant to heat.
