New project, redneck power feed
thriller007
So I i’ve been working on the redneck power feed for the mill. I had a couple of limit switches but I see that they are normally open. I was going to use them for limit switches to shut the power feed off at both ends of the travel. Is there a way to wire them in or do I have to use a normally closed. This is how I am wiring this up.
Following along as parts for my power feed just arrived.
The easiest way to convert those is with a relay. to simplify the wiring I would recommend buying some different limit switches. search for Omron limit switches.
There were many different approaches to doing this. Most of them involved doing a direct drive. I found with the motor that I had that direct drive was too fast and not enough torque so I devised a system to gear it down to approximately half. On the top photo you will notice that the pivot point is rotated upward disengaging the gears. The gears I’m running are at 15 tooth on the drive and 31 tooth on the driven. The motor is just from princess auto. My plan was to Mount the limit switches something like the last picture where you could have an arm that comes down and hits them to shut the power feed off.
Also the control panel coming along
@thriller007 did your motors come with a gear. I have a couple of PA motors that look similar but don’t have a gear on the output.
No my motors did not come with a gear on the end of them. They come with a screw that was more of a acme thread. I turn that down and then press fit on my own gear that originally came on a cx605
Now you have me looking at power feeds again:rolleyes:
Hi Craig, somewhere I read a brief article as to re-using vehicle window motors for power feeds. Wasn't much information in the way of specifics or drawings so I can't explain the setup other than they didn't use window units with plastic gearing. Unfortunately the article didn't mention anything on the power supply. This idea could very well be worth exploring saving you from laying out a ton of coin.
I figure I’ll be in for about $200 when I’m done.
Yup, I’ve got the motor and controller. Just waiting on the power supply.
Hi David, perhaps you would expand on the motor and controller components, what to look for, where you found then etc. Also include info on the power supply. You know all the background music so to speak. Enjoyed the videos!
Best of the Holiday Season to all where ever you be so play safe!
