New patternmaking and sand casting project: Dice Dungeon
Tobho Mott
In Dungeons & Dragons, rolling a natural 20 on an attack roll with the 20 sided die (d20) is an automatic hit that deals double damage. A natural 1 is an automatic miss. We call them critical hits and critical misses, respectively.
Some nights things just don't go well. Clearly this is the result of cursed or unruly dice, couldn't possibly just be luck or karma. Critical hits on the other hand are generally blamed on pure skill. Last week I rolled 2 critical misses in a row and decided it was past time I put that particular d20 on time out. But where?
And so I got to patternmaking...
Not much to tell. That's why this would probably have gone in my "today in my foundry" thread. But in light of recent threads, I'm making an effort to try and treat it like it deserves its own dedicated project thread instead, so the people who only want to see machining related posts can be sure what they're skipping is really something they aren't interested in. 🙂
Kidding aside, if there's anything that anyone wants clarified, just ask. I'll update the thread when there's more done, and try to explain anything that isn't too obvious. Obvious to me at least. Do please ask if something isn't obvious to you.
Let's see.... Ok, I guess the most interesting part of the pattern making process so far here that isn't 100% self evident was using a 1/4" spacer between the rows of "bricks" while using my disc and spindle sanders to put pattern draft on the outside/inside of both rows at the same time. Removing the spacer layer after sanding this taper made the bottom of the top course narrower than the top of the bottom course, creating a small shoulder that gives the appearance of the separation between brick layers, but without creating any undercuts.
I made sure not to round off the top of the lower course or file the spaces between individual bricks farther in than the depth of that shoulder, as that would also create undercuts.
The plastic cobblestone texture is a piece I cut off a roll we picked up in Michaels' Christmas village decoration aisle a few years ago. Plus, in no particular order, there's also wood, plastic sign board letters, and a few ground down plastic polyhedra.
To build the pattern so far I've used dividers, a straight edge, pencil, sharpie, scroll saw, band saw, oscillating spindle sander, disc sander, white glue for wood on wood, CA glue for the plastics, spot/glazing putty, sandpaper, and files. I think I remembered everything. Oh and clamps! Of course, a bunch of spring clamps for gluing up.
Other than that there's not much to say about this one. At least not yet. It's a fairly simple flat back pattern. There is actually a recess on the bottom I suppose. But it should still mold up exactly the same as any flat back pattern, so that's what I consider it to be.
I still have to get out my wax rods and fillet irons to create some "harmful liquid" texture around the melting repeat offender dice who got the death penalty. Whoever ends up with each casting will get to pick whether that is lava or acid, if they choose to paint it like a game terrain model. I added the top of a d12 and a d4 (aka carpet caltrop) as well as a few d20's, just for some variety. Oddly, different coloured dice make different bad smells when you grind most of them away on a disc sander.
Eventually, I promise there will be.some working with metal involved.
Jeff
This is a wonderful project! My own luck with dice rolling is either high or low - the middle numbers seem to rarely come up! I have a friend or two who might like these as gifts, if you're interested in making more.
Thanks Squought.
Interested enough to have already been thinking about casting 4ish copies (if 4 will fit in a 12x12 flask, and after I get one for myself) to use as production patterns...
I do need a project to learn how to inset copies of recessed pattern details (like the back of this pattern where the dymo tape is stuck) into a matchplate board, old timey patternmaker style. Like this matchplate seen on Roscoe Pattern Works' YouTube:
But that's the sort of thing that takes me a while to work up to, and I don't want to hold this project up while I ponder it over and do all the research and ruin a couple practice pieces.
The most fun alternative is casting the whole matchplate, where the hard part isn't technique and/or knowledge so much as lifting a heavier box of sand than what I'm used to. I have a separate thread explaining how I cast matchplate patterns here at: https://canadianhobbymetalworkers.c...minum-match-plate-patterns.14644/#post-192537
I'm pretty sure the flask I built to make parts for a lady's stained glass guitar build a year or 2 ago is big enough to mold a matchplate that fits a 12x12 flask...
The other alternative is simply molding the patterns loose They shouldn't be much trouble to demold individually, unless I really screwed up. Probably best to try them loose once or twice before committing to an unproven gating strategy permanently anyway.
Jeff
Bubbling lava. Or acid. Whatever sort of dangerous and probably foul-smelling dice-melting liquid it is depends entirely on the paint job someone gives the casting.
I have no training and hardly any experience in sculpting, so it doesn't look as good this close up as I hoped, but in hand IRL where you can't zoom in on the ~2" pit of doom, I think it'll work ok. And I know I'm at the point of diminishing returns where putting in more time refining it won't improve things enough to be worthwhile. If the dice more or less look like they're melting into a frothing pool of doom, I'm satisfied.
It was fun playing with hot steel balls and wax for a while, but the stuff is a little frustrating to get used to pushing around, then before you know it the ball cools off a bit too much and you do something rough looking that you have then go back and fix. Arrgh. The guys who do lost wax casting by sculpting the wax patterns directly... boggles my mind.
I don't expect the wax to hold up for a ton of molds, experience using it for making fillets on patterns tells me it's a little soft, and ramming the sand into it will take a toll. But it ought to last long enough to cast a few copies to use as patterns.
I thought about sculpting the lava in (friendlier) polymer clay instead, onto a lava-free casting. Then I could stick the whole pattern in the toaster oven to harden the Sculpy without burning the original wood and plastic pattern, and cast my permanent patterns from that. But using the wax will work, and this way the final castings will just be copies of copies, not copies of copies of copies.
Jeff
I like to use graphite powder to prepare new patterns. Not just dusted on, I gave a brush a short haircut and use that to somewhat aggressively scrub the graphite in. Not one pattern letter popped off! Used CA to attach them basically permanently this time.
The.grapbite scrub gives the pattern a silvery sheen like it's been coloured in with a pencil (if I may state the obvious). I also counted on the brush to polish the wax a bit, smooth out any rough spots in the hard to reach nooks and crannies.
Got 2 rammed up this afternoon before I had to leave to pick up my daughter. Took a few pictures as I went...
Positioning pattern in drag side of the smallest flask that still leaves room for a runner and in-gate:
Gratuitous pouring basin:
(Mostly) Finished mold:
Just needed the sharp corners at sprue base and end of in-gate radiused off a bit here.
Close-up of Dymo tape label impression:
I very much want to try (again) to cast individual bondo pattern letters using embossed dymo tape as a mold sometime. My first attempt failed miserably, but I've gotten some good tips since then from a fellow who did manage it once...
Close-ups of dice and lava impressions:
Added a bit of parting; makes it easier to see the details. The 1's on the dice are just barely visible. I hope they cast out well...
Additional details of cobblestones, text etc.:
Mold #2 rammed up:
If I could, I'd wait to pour these until I have my 4 pattern copies rammed up.
If I could, I'd also make one extra mold and pour a copy of the "home sweet dungeon" plaque in Al too while I'm at it, to keep for a pattern. So as to free up its cast background and my plastic pattern letters for other jobs. Because this was always the plan for that pattern, those letters were just white glued on, for easy soaking back off of the aluminum background.
Friday is game night and I do plan to have at least one Dice Dungeon cast in time to bring with me.
But I also have a dinner thing on Thursday, and an early Friday morning. So depending on real life intervening or not, I might have to just bang out whatever I can have ready for tomorrow after dinner instead of pouring all 5 molds in one heat. Time will tell.
Jeff
I poured just the two I had already molded.
Woohoo! Happy to see all the details came through.
Just have to brush off the sand, cut off and grind down the in-gate on one of them, and it'll be ready for the game table on Friday.night. Unpainted. I don't have the eyes for that anymore.
Jeff
I should have gated into the flat back that gets sanded smooth anyway. Gating in from the side required more grinding off of sand cast texture than I want to live with...
So the first 2 probably won't actually be useful as patterns. But I did get one playtest-ready for tonight's game session...
Jeff
Cool idea. Maybe a little too small, but hey the inside doesn't need a flat bottom if I use it as a can coaster. It kinda looks like it wants someone to knock it over though.
I don't think my D&D night mug is gonna fit... 🙁
Along similar lines, I always thought my "bug out" castings could keep wasps out of a beer just as well as they keep spiders out of a sprue. 🙂
Jeff
Got 3 more copies cast. Poured them a little hotter than I needed to so there's a little more sand texture showing than they had to have. But with a little touching up they'll make decent patterns. Gating on the flat back this time for easy cleanup, I'll just have to remove a tiny bit of flashing and sand the flat back smooth after cutting the gate off - everything visible when It's sitting on the tabletop will retain the as-cast texture.
Most of the steps in the molding and casting process are shown here, plus a little about about how I made the pattern.
These 3 new castings plus the original pattern will be molded up together in an oversized flask, and from that I'll cast an aluminum matchplate pattern sized to fit my 12x12" flasks. I thought I had a flask more than big enough, but it turns out my biggest is longer than I need but a little bit too narrow. I'll have to build a new one that I can use to cast the matchplate. And any other matchplates I might need for my 12x12's...
Then I'll be able to make up a mold and cast 4 pieces at a time really fast and easy, since much of the hand work that goes into making these molds will already be locked in place on the matchplate. With 4 per mold I'll be able to make ie. a dozen dice dungeons (3 molds, for the sake of comparison) in perhaps half to 3/4 of the time it took me to ram up and pour the 3 smaller individual molds these new castings came from.
Jeff
After a nice week off spent out west with my parents in West Kelowna BC, I'm back home and able to get back to work.
Next step: Build a new flask big enough to mold and cast the aluminum matchplate fitting my 12x12" flasks. And a bottom board for it.
It is big enough that I should probably add a crossbar to the cope, to prevent it from spreading if the long sides try to flex outward. The drag could get one also, I suppose. I also need to add some sand retention recesses to the inside face of both flask halves.
I plan to use the method described here to cast the matchplate with 4 pieces on it: 'Super easy durable cast aluminum match plate patterns'.
I haven't cast a matchplate this size before, but smaller ones with max. 2 pieces per mold have come out great, so I don't anticipate trouble. And now that I have this flask that is custom sized for it, making more cast matchplates for my 12x12's won't seem so daunting. Although this will be quite a heavy mold to ram up and manhandle around the shop...
Jeff
That "Time Out" piece...is that for @Chicken lights?
Btw, very nice work!
The flask is now finished. Sand retaining features were added to the inside walls of the flask, as well as a crossbar for the cope to help support the wide expanse of rammed sand when the cope is lifted off the drag.
I also measured and cut out the drywall spacer that will form the plate portion of the matchplate pattern. The cutout in the center will fill with aluminum to form the plate between the cope and drag features. Maybe you can see that I've also traced out where the patterns will be located when I ram this mold up.
I've never been 100% happy with the M's from my smallest pattern letter font (which were actually meant to be sign board letters). The inside corners under the peaks of the M are too thin and sharp to cast as well as I'd like. They come out a little rough looking for my taste.
So, I've been trying to soften those deep narrow sharp corners with some 2X build spray paint. The tricky part is to not fill in all the cobblestone texture while I'm at it. I think it should help, but I may have to repeat this on the cast matchplate too. We'll see.
Next step once fully dry is to give them a good scrub with a coarse haired paintbrush that I gave a very short haircut, loaded with graphite powder. This covers the pattern in a thin film of graphite, the scrubbing acts sort of like colouring it all in with a pencil, and makes for extra easy de-molding). Then I can start ramming up the big mold. Not sure when I'll find time for that, but hopefully this week...
I also need to chop up a few more of the scrap cast aluminum worn out corn harvester parts I got from the repair shop down the road. Seems to be good cast aluminum, probably A356. Even with some embeded steel bits, they're still easier to process for adding to a crucible than the car wheels I have been using for years. Plus they're within walking distance. 🙂
Jeff
The crossbar in my cope wasn't enough. I needed to make it protrude.deeper into the sand, and/or have more than one of them. The cope began to drop out when had only been lifted maybe 3mm off the drag, I could see the rammed sand cracking on top of the cope. Set the cope back down quickly enough to hopefully save the mold and opted to roll it on its side to open up instead of trusting gravity. It almost worked.
Unfortunately, on a mold this big and heavy the wooden flask alignment pins had enough give in them (usually helpful) that it allowed a slight mismatch/double imprint of the dymo tape labels to occur on the back side. The cracking probably didn't help either. To me that's a deal breaker, especially when casting production patterns. Had to break out the cope to try again soon, but at least the drag is still good. Can't win 'em all...
I'll probably go directly to opening the mold sideways when I try again, because that cope was heavier than I expected. I'm going to need help to get the finished mold in place as well, luckily my wife's uncle is staying with us. But for lifting off the cope at the molding bench it's a bit cramped for 2 people to get in there to pick it up and also keep it level.
Really this one is big enough it ought to have been rammed up on the floor, not the bench. I made my best sand rammer patterns as separate ends to be cast and attached to wooden handles specifically so they could be used to make either bench or floor rammers, but of course I still haven't cast a second set yet to install on a 4' longish handle...
Jeff
PS. A little off topic in this project thread, but since I mentioned it: The peen end of the rammer castings is one of my more challenging patterns to mold, it uses a loose greensand (actually Petrobond) core to get around an undercut. Hopefully I have not posted this before:
Found time to try again after work today. Wound up losing the drag I thought I'd saved when a pattern fell out and tore a bunch of sand out with it, so I had to redo the whole mold. 🙁
Thank goodness my wife's uncle is staying with us, so I had some help moving this big beast around. Opening the mold sideways worked fine and avoided the risk of the cope dropping out again. (The drag was supported from.below by the molding board.as.I lowered it here after separating the mold halves, so it never had the opportunity to drop out like the first cope tried to do when nonvertical and unsupported)
The runner will be in the center of the 12X12" molds with the sprue at one end when I cast the actual "parts", but for this larger mold to cast the matchplate there is no runner and the sprue is at the far right end of the mold cavity. I've elevated the leftmost end of the mold in position for pouring by somewhere between 1/4" and 1/2" above level, to promote laminar filling of the mold cavity from right to left, as I think I have described before. I always do this when casting wide thin stuff. Probably hard to notice it's not quite level in this picture, but it is. The fire bricks in the background aren't necessarily level either, that wall is actually a temporarily repurposed burnout kiln lid.
Closing up the mold while it was back up on edge again did make keeping the drywall matchplate spacer between the mold halves from moving out of its designated place a little tricky, but I think it ended up close enough to the alignment I intended that it'll all work out ok.
As long as the more than 15x15" of mostly unsupported cope sand currently hanging over the middle part of the drag doesn't fall before I get to pour it that is! Like say if another nightmare red squirrel got into my shed again and happened to scamper across the mold... that might be enough to do it for all know. Hopefully tomorrow I'll have time.to pour it before I have to go pick up my van. If not, it'll have to wait til after my camping trip & hopefully it'll keep for that long because I don't want to ram it up a third time! But with me being away for most of a week, it's.really their perfect opportunity to come for their revenge. The squirrels that is.
I not sure if the #12 crucible I use for aluminum will be sufficient, so I've prepared one of my #16's. Probably I'm just being paranoid, but the 16 is also a better fit for some scrap cast aluminum worn out corn harvester parts I got a bunch of from the tractor repair shop down the road, which I am very happy about. Melting them whole will.be awesome, I'm not used to not having to chop up the scrap cast aluminum I melt. Normally in the past I've used car.wheels.for 90% of my aluminum casting stock, and they require significant processing to fit.
Jeff
I'm glad I went with the #16. It took just about the whole thing! This was last Tuesday.
Then on Wednesday I went camping with the guys, our 25th annual trip. 5 nights in the woods wondering if my casting came out. Did the cope sag.before I got it poured? Did the metal get to all the corners? Etc. etc.
Well, at first glance it looked ok.
Upon closer inspection, the cope did sag. And crack. I needed more better crossbars in the cope and maybe some gaggers to support the wide area of sand that was unsupported. A matchplate that is flat on one side and concave on the other is useless.
When it did sag, some sand fell into the drag as well.
Oh well, win some lose some. It really sucks to lose one this big though. Back to the drawing board.
Jeff
