Former Member
Guest
Not clouded, keeping an open mind doing the research. Remember I am an engineer too and develop my own products and tooling and machinery. When things don't add up correctly question until you've exhausted it.
Thanks @gerritv you just made my case. In an earlier post I mention the trick of an old machinist of skewing the knurling tool for easier cuts. In effect yes there is some cutting action happening as the edge or point of the tool contacts first. However more importantly the removal is just enough to cause reduced displacement of material and still causing work hardening (part of the desire effect). This by definition is "Knurling".The same way a lathe cutting tools works, it cuts at the point of contact. You will have seen that this photo is part of aligning the tool, this particular photo is of getting the angle correct. The wheel never cuts along its full width, only the left tip. The wheel must be at an angle (usally 30dg) for this to work.
The operation always starts at the end of the work piece (or a step if knurling in mid of some length). 1mm or so wide, crank in 0.5 of pitch and then feeed slowly axially. With the wheel (and thus tips) at an angle, it cuts as you move along.
I suggest you either model this in Fusion360 or make one. Even better, do both 🙂 . Like the Euraka relieving tool, this is easier to understand when you see it in operation than it is to explain in words. If you make one, get the proper wheels, Quick/Zeus/Accu-Trak/Dorian etc. all make cut wheels. You will notice that these are narrow, since they cut only at the leading tips.
I will start a thread when mine arrive and I have the tool built. Single wheel only for RAA pattern
Gerrit
Cut Type Knurl Holders
CUT TYPE Knurling is not widely used in U.S. market, but common in the rest of the world. The knurling dies are skewed (layed over 30°) to the work piece axis creating a cutting action rather than a forming process. Often times when knurling non-ferrous material (aluminum, brass, etc.) the forming action work hardens the material causing the crest to become brittle and break off. Not so with the cut type knurl - the milling action leaves a sharp solid crest for a perfect knurl.
Gotta say you are funny on your views on occasion and how you call on only what suits your view.That does not sound open minded to me. I'm thinking perhaps we have fundamentally different opinions of what it does mean. To me it means a mind that is not latched onto a particular view or trying to prove points. It is a mind that let's go of their convictions and beliefs and willingly considers other alternatives. In this case, in the hope of learning something new or different.
But that's ok. We can agree to disagree on what it means or even if it is necessary to be that way. We can also agree to disagree on everything else about cut vs pressure knurling.
Unfortunately, I think it also means I am probably not going to be much help to you on this one.
Hey @ducdon, is there not a hole at the bottom of the tool post that you can pin it to the compound slide? The tool post should not move under any circumstances. Also, check that the bottom of the tool post is perfectly flat in relation to the compound top surface.I fight with this $#&@ thing every time I use it. I need to bolt a plate to the side of the quick change and clamp it to the compound to keep it from rotating on the tool post,
You should ask them a question about oil some time.... 😀Well I think this topic has been beaten to death. 107 posts, come its just a knurler.
Agreed. I didn't realize my tool frustration would become so profound a topic. I didn't see it coming and frankly was a bit overwhelmed as to when to jump back in.Well I think this topic has been beaten to death. 107 posts, come its just a knurler.
Just finished blackening my knurler with Brownells Oxpho Blue.
Ordered it thru Amazon.CAHow did you get that across the border?
