Well, this evening started with much promise - a delivery awaited me at home - a new 6 jaw, 6" D1-4 chuck from Vevor delivered for just under $300 bucks.
https://www.vevor.ca/lathe-chuck-c_...th-d1-4-cam-lock-backing-plate-p_010790897201
Unboxing went well.
Well packaged, light oil coating. No issues there.
Noticed right away that no holes or edges have been deburred, they are sharp as razors some of them, I kind of expected this at this price point, they cut as many corners as possible.
Next was the cleanliness - or lack thereof. Again, expected except actually even worse in areas than I thought - its really thick the grinding dust inside the bore.
I really wanted to just toss this on the lathe as received and check its runout, but that is not to be...
The cam lock D1-4 backplate, while not undrilled as
@canuck750 suggested, that might have been a better scenario. The holes for the screws that prevent the cam lock studs from rotating have been drilled too deeply and do not prevent the studs from rotating. I also can't just drop a washer down there, the hole is too small a diameter for any of my ready at hand washers...
So the debate is - do I make a custom set of washers to jack those screws up, or do I deal with Vevor to see if they make it right, or both? I'm inclined to do both.
This is just a first step to determining if the chuck is fit for purpose...
The Cam studs themselves seem to be correct in length - they match up with ones from my Grizzly (made in china 12 years ago), and seem to engage with ~9 turns into the backplate but the thread is a looser fit than I'd have liked.
I continued on a bit, separated the back plate from the chuck (it was not screwed on, those screws were in the top of the box). Took off the plastic backing plate and its bone dry in there. I definitely need to clean this up before going further.
One question I do have on chucks, when popping the jaws out - what comes out first - jaw 6 in this case or jaw 1? I'm inclined to believe its jaw 6 as only 1 has a touch of blue paint and with the direction of the scroll for loosening the blue painted one will come out last. Can't see any individual jaw numbers yet and want to know order of operations to put it back together properly.
Anyway - the thing is coming apart and I'll clean it and put it back together and then try and grab some runout numbers...I could (and probably will) just mount it and just hand turn the lathe spindle to get an idea of runout, even without the studs locked in...
