@Susquatch It is my understanding that you need some kind of disconnect after the plug. a 3HP rated switch would do the trick, and be fully code compliant.Thanks Darren, it's not really about what works. That's the easy part.
Fuses sound like a good idea, but are they required by code?Just to make sure we are on the same page....
220V Single phase outlet on Wall.
Single phase lathe wiring plugged into it.
Then a 3HP disconnect either at the plug or on the lathe.
From there to the fuses, and on to the VFD.
A thumbs up will do... LOL!
Seem redundant, that's what the breaker is for?
I don't know if this will help. Here's the inside of my lathe control box. I have 220VAC single phase in. Output from VFD is 3 phase to the 1HP lathe motor. Schematic attached too.
I just came across this and thought someone might be interested.
Oooh...like the Cone of Silence in Get Smart!! I love that idea!Could you mount it above ( Ceiling )so it can swing down or slide down on drawer sliders?
A suggestion - a nice solid monitor arm. They show up on craigslist, Marketplace, etc. for next to nothing, will support 10 to 15 kg, and provide a solid swing away mounting.
Once you get it done, and are loving it, you may consider a remote on/off and speed control pot mounted someplace handy.After much painful thought, I've decided to throw in the towel on front mounting the VFD. I'll temporarily mount it on the front while I set it up and then move it to the back outside of the control box where it's hard to get at. There just isn't a place up front where I can put it permanently and I'm not buying another VFD just for the removable control keypad. I'll add a simple swarf shield out back to keep it from ingesting swarf, accept having to crawl behind my lathe to re-program the VFD when I need to, and get on with this project.
I'm reminded of what a CEO of my previous employer said to me once. "There comes a time in every project when it is time to shoot all the engineers and get on with building the product." He was right, but I think a little too aggressive and we paid dearly for that at times.
Anyway, I've procrastinated a decision on this project for way too long and I need to get on with the VFD 3phase motor conversion.
I'll have to look at the electrical code again though. Something tells me that this might be outside the envelope.....
It really is easy to do. The electric braking is a great adjustment to make in the initial setup too.
Don't you think that's well worth the cost, considering how much time you've spent trying to find other less than perfect alternatives.So I tried to buy a remote control for it....
EMotors wants over $200 for it. I can buy a whole VFD for that!
After your disconnect on the machine, the CEC no longer applies - from a code compliance point of view. After all, you have modified the wiring which makes it no longer CSA approved anyway.
However, if you do this, then use a flexible steel conduit, and STRANDED of the appropriate gauge in the wires to/from the box that can move.
