If that all makes sense.
Yes, it does. Even for a guy with no CNC.
The VFD does run my mill. And it doesn't accelerate/decelerate all that fast. But if the operator looks at the situation and doesn't register then it doesn't matter. My mind was clearly somewhere else. In hindsight, 20-20 being what it is, there were so many signals that something was wrong. In 16 years the chuck has never unscrewed and turning pressure should force it to screw on and tighten.This is one reason I love the VFD running my mill. I set the acceleration rate deliberately slow enough so I can see which way it is turning. My brain is hardwired to watch it spooling up - no idea why!
Maybe you need a backup beeper..... LOL!
What is scary is that I thought I was aware of what I was doing.
Me and a large router bit about a year a back....I learned a hard lesson about machine safety about 20 years ago with a table saw without a blade guard. won't say more about that unless asked.
Hand held routers scare the bejebuzz out of me. Likewise jointers.Me and a large router bit about a year a back....
It was mounted in a table at the time... Material failure + improper work holding + 1/2" spiral bit. Not a lot of fun.Hand held routers scare the bejebuzz out of me. Likewise jointers.
@jcdammeyer I'm very glad you're ok!
No, I wasn't totally brain dead, just made a bad assumption in a moment of fatigue. Saw off = safe. Not really, and definitely not until it stops spinning.Dis you?
www.instagram.com
Not a bicycle, but I know you can set an upper rad hose on fire, if the skidder operator is an idiotWe’ve all been there. As machinists, everything we work with is some combination of heavy, sharp, or hot. Did you know it’s possible to set fire to a bicycle?
What's that saying, it was idiot proof until they made a better idiot? 🙄Nothing is unpossible where idiots are involved.
Good point. So far no one on the South Bend group has come up with a method keeping the chuck from unscrewing. Not without a major rework of the machine.For me anyways, the real lesson learned was that machine / safety equipment / etc. aren't only there to protect you while you are paying attention. They're there for when you are not. And not paying attention can mean looking away for just a split second, or not realizing your chuck is spinning backwards. Sure the safety features help keep idiots safe, but they also work for smart distracted people. PPE has its limits to what it can do for you.
I'm not the safety police, I make suggestions when I see something unsafe but I won't stop you if you insist.
In this case - having a lathe that can reverse, but no way of keeping the chuck from loosening seems like a bad combination. I would think that even the possibility of ruining the job you are working on if using in reverse would be enough reason to ensure it can't loosen, and safety comes along for the ride.
