Hey YotaBota,
I cannot really run the machine per say as it it pretty much all in in pieces, some at at YYC's place, some are being shipped out to Virginia and some others are being shipped to Lee and YYC in Alberta in a couple weeks. The bed is resting in my drive way LOL
Best I can do is if you let me know the gears you want and I can pull the head apart, take pictures, measure etc and if you want them I can ship them out to you for a very reasonable cost.
Have you checked the bearings for wear? It does not take a lot of slop in them to start causing a rattle. The Timkin Bearing (19) is just like a wheel bearing type bearing and you apply pre-load using Spindle Adjusting Nut (14). Basically tighten up until there is resistance turning the shaft and then slightly back off (1/4 turn or so) until that resistance is gone and the shaft spins free with no end play. The bearing (15) is not great at absorbing axial force and is essentially there for rotational alignment etc. This bearing typically fails before the Timkin one that absorbs the axial loads. When the series 2000 came out they doubled the Timkin bearing for forward and reverse loading (probably due to the wear rates on the back bearing (15)).
The spindle adjusting nut is secured from backing off by a set screw. Under this set screw is supposed to be a small brass dowel to prevent damage to the threads. You can add one by clipping off the end of a brazing rod if yours is missing.
