Huge list of unfinished projects for the new year
Ya, it's embarrassing. But it isn't a race. It's a labour of love. And ever since my stroke, my wife won't let me spend as much time alone as I'd like. But my best excuse is that I'm so busy doing things on my lathe that I don't have time to stop doing that stuff so I can install the DRO and motor/vfd. Also, I want to do all three at the same time.
In my smithing work, I always have a need for indicator rods and precision pins. So what I want is sort of like a cylindrical grinder but for small rods and pins with high precision diameters plus/minus 0.5 tenths of a thou. Think of it a bit like making a bunch of really long gauge pins.
I'm hoping that is true. I'm waiting for your report after using it. I have sharpened a few drills with the Drill Doctor, and I'm not happy with it. But it's better than my bare hands.
Yes, I keep all my swarf separated by type in big garbage cans. When I get enough, I take it to the scrap yard.
Yes, I have a 20 ton press. I've always wanted to pour ingots, but that would require a kiln and its trappings. I've sort of kissed that idea goodbye. At my point in life, and with my priorities, I'll never get to it.
I don't really need a kick in the pants. It's really all about priorities. I'm plenty busy enough to keep me happy. I pick my priorities based on the needs of the moment and the way I feel at that moment. I don't watch TV or YouTube. But yet I am always busy. Perhaps the most relaxing thing I do is follow the forum. But even that I usually do while I'm waiting for something else, or when I'm in bed (like right now), or on the long drive to Windsor or London and back for those times when my wife does the driving.
I usually go to my shop to do something that needs to be done. I don't normally use a list to guide what I do. I just do what needs doing at that moment or whatever hits me in the face.
For example, today I was looking at how to disassemble a live centre I have that has a brinelled bearing in it, I was also evaluating the hardness of the R8 shank I have to machine for my microscopic center. My mother passed away on Christmas Eve so I didn't have time for much shop stuff. Those were the things I chose to work on.
The indicator base is really a thick steel plate screwed to my headstock behind the spindle. Its there to provide a strong convenient spot to stick a magnetic indicator base.
The toolpost grinder is a work in progress. I have a thread on that project.
The 3-way tramming fixture also has a thread on it. It's a system I'm working on to do both nod and tilt simultaneously. I've already built the reference surface for the table. It has three identical steel bases that sit on the mill table. I used the surface grinder to make them all the same. I also acquired and polished a brake disk rotor that sits on the bases to provide the reference surface. Now I need to make the indicator system that attaches to the mill spindle.
Last but not least is the parting plinth. That is something that only exist in my head right now. When I start working on it, I'll probably start a thread to document it and help others.
I don't have an existing thread on this project yet. Mine is a modification of his. In my opinion, his doesn't retract enough. I plan to look at his Gen 2 device to see if I can improve on it. My days of patenting things, or producing and selling things are over. He would be welcome to any improvement ideas I might have.
Sorry to hear about your mother. My condolences.
or a Threading autostop or auto-retracting threading tool holder like @MrWhoopee has designed. I'm not sure how much he'd like that though because he sells these.
I like it just fine, in fact I encourage it. While not as profitable, I find it equally gratifying that someone would want to copy my work. It's one thing to buy something, another matter entirely to build it.
Absolutely! I am currently working out a change to address an issue that has been on my mind.
That sounds exciting!
While you are at it, it also needs a different geometry on the over center kickout arm. It's too high. The bigger the lathe, the higher it is. It's difficult to arrange a solid trigger mechanism that isn't in the way. I've been thinking about a bottom sear type trigger like on a bolt action rifle. You would still need a cocking lever but that can be anyplace.
It sounds like you are referring to the original with 1/8" retract, which (IIRC) is the one you have.
The new, 1" rectract model has exact;y what you are describing. (Something about "great minds....")
Have you watched the video that @TorontoBuilder posted above?
I created a FB group (I know!) specifically for the discussion of automatic half-nut releases and auto-retractors.
Everyone is invited. https://www.facebook.com/groups/953434963067580
Oh this is slick... @MrWhoopee designed a pretty good trap to get me to return to the facebook 😉
So this sounds like a perfect project for a "group build along". Even better because there are a few design iterations it can start with a design review to see if the design can be improved further. Then 3D modeling of the project (because susquatch needs to work on learning fusion more 😉 and then a build.
I have a really clever friend Brian who needs to work on his fusion and machining skills, and who has insightful comments on designs. So who wants to start a new thread for it?
I'm very sorry to hear of your mom's passing John. She must have had a well storied life.
The indicator stand desire came when I saw robin renzetti's stand...
Then Michel made a bombproof base
I got a copy of the indicator stand plans from Michel Uphoff, including the 3d versions of the file.
I'm starting a specific thread for this build and invite others to build along with me. Your reward, a really robust indicator stand.
So, I have one more really special project I want to do asap...
It has morphed now though.
I used to be really into Kinetic sculptures, big wall mounted ones. I also wanted to make a regulator style clock with westminster chimes, but wife hates clock chimes, so much so she wouldn't let me take my grandparents Grandmother clock. So I thought I could make a pocket watch with a custom made silver case that I engraved myself instead.
but I've wanted to make one so long that I have since given up watches entirely in favour of my smart phone.
But an engraved custom case remains a thing I want to do, but I've found the best substitute project that has some of the same machining challenges. It is something I'll need and use often. A dial indicator.... with a large face, custom engraved silver case
of flatness gauge, the indicator stand, or the indicator?
My my anticipated use the flatness gauge can be as simple as a wide parallel bar 6" long with a hole in the middle for an indicator, or a more complex build like this:
For some reason I missed your response. Easy to make something like that. And I think nice to have too. I'm not sure how complex the rabbit warren under that hole is though..... I have actually been working on something similar using a small granite block with an indicator post. But after seeing that, I may rethink the concept. My only complaint with your concept is that you are only measuring half the difference.
I can only imagine where I'll end, up after watching Robin's video. Sound familiar?
Ya, funny enough, I have that little project on the study table right now. Some members will recognize the parts from other related posts. Despite the current timing, it isn't on my project list post. I'll have to fix that.
I watched all the videos. They are not really about a flatness gauge.
But YES! They directly address my ongoing concerns about the flexibility error built into most indicator stands......
There are a host of problems with those things. It speaks directly to my constant harping about the fundamental fact that everything moves when a force is applied. It isn't if, it's only how much. It's one thing to use an indicator to measure a deflection but you also have to appreciate how much your indicator system moves too.
I personally LOVE my Noga indicator stands. Buy they are not bullet proof. I got an amazing deal on a FISSO a few years ago. As good as the Noga (black) is, the Fisso (burgundy) is clearly better.
Although the Noga is a bit longer, the arms are much smaller and flex more. It should be the other way around - longer should be fatter and stronger. Both have multiple fine tuning and metrology attachment mechanisms. I had planned to do a force ratio comparison, but that project slipped well below the 42j where it started. I guess I should add that to my project list too.
I like the magnetic base in the last video you posted, but I'm not convinced that this massive effort is anywhere near worth the effort. Note the robust attachment of the Fisso base attachment design.
I personally doubt the magnetic base itself is worth improving. Most of those bases are exceptionally strong - even the cheap ones. The 1/4" stud used to attach to them is a whole nuther kettle of fish though. Thankfully, it is quite easily improved - dirt easy in fact.
Although the Noga is a bit longer, the arms are much smaller and flex more. Both have multiple fine tuning and metrology attachment mechanisms. I had planned to do a force ratio comparison. But it slipped well below the 42j where it started. I guess I should add that to my project list too.
I like the magnetic base in your last video, but I'm not convinced that this massive effort is anywhere near worth the effort. Note the robust attachment of the Fisso base attachment design.
@Susquatch The flatness gauge is a completely different beast, it's lazy, lies flat on its face all the time like it is in a drunken stupor and does very little work around the shop.
I want one to inspect granite surface plate before buying... and to measure scraping efforts as well
BINGO! Me too! If you look at the granite stand on my earlier post, I have been looking at adding a long 1" bar (or pipe) with an indicator mounted at the end of it that I can use to sweep surfaces. It wouldn't be perfect, but it would help avoid gross anomalies.
But the videos you posted were about indicator stands.
