@YYCHM honestly thank you for asking, gave me the motivation to spent the hour I had after getting home before running out again for an appointment.
Fiddled around with the pump and found it is not original, what’s left of the pump was cut in half through a threaded hole, a spacer scabbed on and a replacement through bolted on, with a shop made coupler.
I’m getting the feeling more and more my lathe was the redhead Ed adopted stepchild rented mule lol
Took the pump apart and
@RobinHood you are correct a simple gear pump, that has no bad seals, missing parts, or gunk.
Disappointing I wanted a ripped O ring in a size I have lol
But then I noticed the gear spins on the main shaft!! No key, no flat spot, no spline, no press fit, no weld nothing!
I’m turning the TIG on and I notice a red line
Looks like it had a small recess turned at the shoulder and red loctite
Brake clean and some fresh loctite.
Hooked it up to the cordless and it’s working ten times better.
Didn’t quite have time to finish reinstalling do to the goofy redneck creation. (I feel a little shame here)
