Tips/Techniques HOUSE OF TOOLS LD 1236G
Tips/Techniques
Contactor update;
As mentioned above the lathe would take its sweet time shutting off in fwd, sometimes it was instant but most of the time it was in "danger mode" and not shut off immediately. I pulled the forward contactor as seen in the picture, sanded and cleaned them with contact cleaner and now three days later after loosing my mind on the wiring it is all back to normal and shuts off as it should.
A note to the wise, take a shite ton of pictures, if your like me and think electrical is one of those "dark arts" that is best left to the Wizards. I would even go as far as to colour mark some wires, I had an issue with the contractor jumper for the magnets to energize and it was extremely frustrating, I ended up zooming in on one lead (two days later) in my pictures and realized it was in the wrong place. I was also not able to find the proper wiring diagram anywhere, now if the contractors do really "pooch" in the future I have a bit of a clue, as I guarantee I will not be able to get replacements of the same.
If you're careful you can clean them quite easily, mine had metal clips on the sides to open the contactor housing.
I am an electronics guy and yet I still use letter and number wire labels. Easy to make notes and positioned properly, also easy to take pictures.
Gardner Bender 42-035 Wire Marker Booklet, A-Z, 1-90, and Symbols, [Booklet Contains: 1-15 (6/Ea), 16-90 (4/Ea), A-Z (2/Ea), Symbols (2/Ea)] https://a.co/d/9QYUuep
You are lucky you didn't let any magic smoke loose.
OH, I intentionally left that part out trust me on that, it had a 3 amp fuse, replaced three times and blew the panel breaker twice, arched out the extension plug once, STOP LAUGHING, , it sounds more dramatic than it was, oh, and the breaker attached to the right side of the bottom contactor holds residual energy, got a little tingly twice, STOP LAUGHING.
On a good note I was wearing rubber boots,,,,,,,,,,,,
..... sorry, can't stop laughing.....you learn faster than I do ..:rolleyes:
When I changed mine I made a drawing of terminals and wire numbers, took pics, and it was still hard to get everything in the right places. Wish I would have had that booklet Susquatch has.
Looking good! my only suggestion would be too move the lathe out from the wall on the tailstock end to allow easier install/remove of the tailstock .
As far as inserts maybe post a picture of the lathe tools you have maybe give a better idea of what will be most commonly used but this is a start the tool is sometimes task specific but the inserts' can be the same or different.
A QCTP maybe something you want to look at if you get tired of swapping in tools into the 4 way post.
Its been a while since I've been on this site, yes the first thing I did was put a QCTP on it, thank you. I have been researching VFD's but as long as the contractors still work I'll leave it alone and work on learning without loosing a finger or an eye, ;)
Hey@MooseMeat! Welcome from Campbell River! If I’m reading the thread correctly, you are north of Nanaimo? I’ve DMd you.
Edit: for some reason I can’t address a DM to you. Maybe you’re too new in the system?
I’m willing to get together and go through a few things with you if you are interested. I’m not an expert by any means, but I’ve made a lot of chips in the last three years.
Anyway, the offer is there. DM me if you’re interested.
One of the two industrial electricians that I have worked with that I actually liked gave me an almost full Thomas&Betts E-Z-Code pocket pack wire markers . I guess they aged out as don't stick too well. Instead while reading about wiring on Practical Machinist, a couple of electrical techs said that they use a Brother labeller . My wife had given me one from Staples to help with my organizing my little drawers . The cartridges are expensive though. It's much neater than my masking tape and felt tip.
I'm on my never ending VFD install attempt. This time I'll be using the labeller. Before pulling the old one out, I tagged the wires with my masking tape and made three pages of lists . There was no guarantee the wiring was correct, since I did it.
I bought a Brother P-Touch Labeller a few months ago. It can handle shrink wrap labels for wiring. Very happy with it.
I don't think VFD's are that complicated to those in the know, (from all my Utubing) I wear rubber boots when doing any wiring, just saying....;)
Depends on the VFD. To get it more adaptable, there are more parameters to program. It is an automation device after all.The English manual is a mere 420 pages long. However I switched it on from the panel and there was a strange sound . At first I thought the VFD had crapped out but when I opened the cover, the belt was turning. The pot worked but the controls don't. I consider that a tie. There some more programing to do, but I now can use the lathe, that is after setting up the tach. The oil leak did a number on the duct tape and the reflectors.
All I would need it to do is control the forward/reverse and speed, and put remote switches where the original switches are located, I have a belt driven lathe, but I don't think that matters much in the big scheme of things.
It really doesn't look that complicated, but I am no electrician.
I'm looking for E-Stop, forward, off, reverse, jog reverse, jog forward. They are all there, I just have to program them in. I'm no computer nerd, I'm far too old to have grown up with PLCs .
