Hopefully you found out before making the drive. I'm a great believer in fate, either the thing is a POS and you are saved and/or there is a better one waiting in the wings.
I have always used a little dropper of cutting fluid for jobs like that. (my wife's empty cooking oil bottles work good) I'll never own flood cooling for anything I own. Too much mess, too hard to contain, too hard to clean up.
Well, already not listening to @Janger -argh! - I cleaned the coolant tank and filled it with the blue cool mist coolant - not to messy. I do agree the soluable oil can be very messy -especially if there is lots of spray.
Cleaned up any remaining swarf and a few missing fasteners, couple electrical tightening. Changed out the gearbox oil and pressed play.
The saw cuts great and straight!! I just need to make a quick lock lever, and a cut stop. The 12” cut extension is there as well.
Now I have an old fashioned power hacksaw to sell and ???
Hey @Janger - my saw is used and had a few little things to fix/fit. The shop I got it from has a big conveyor set up and the stop was probably lost. The bolt is pretty tight in the securing hole so it may not have ever been used. It is a circa 2015 model - it was $850. It cuts very well and the vice lock is great!
@YYCHM I have a chop saw, a portable bandsaw on the stand (king porta-band) type thing, the old auto hack saw and then it was plasma or the torches - or worst case just mill it (a lot)
I have a bunch of projects planned for thicker materials and some larger rounds of steel (like your face plate type thing) that would be hard to cut. I also have a few other steel projects to tackle that the other methods are a bit more impractical to use.
The bigger saw should also allow me to pick up on some of the barn find steel I couldn’t because I had no way to reasonably cut it to size.
