CA-BC Grizzly order - anyone on South Island need anything?
British Columbia
Type
Tool
What makes it a bit more challenging at least with online calculators & formulas is the logical assumption you are cutting metric threads with a trapezoidal tool or ACME threads with an ACME tool. They can spit out PD using wires or whatever as long as you stay within the corresponding system. I could be way off base here, but if they are cutting inch pitch with trapezoidal tool to serve N-Am market so the dials correspond to typical 0.100" per rotation, it would be an odd duck, but would work perfectly fine. Seems illogical to do it this way, but so are many similar things on these machines. Anyways, I'm pretty sure I can just lay out the shaft OD & appropriate thread form in CAD, do a path guided cut along a pitch equivalent helix & it will yield a section view I can pick off any dimension to confirm. I can confirm external thread parameters this way.
Maybe better yet
IMHO, flexing cast iron to take out backlash is a flake move. Fine if it was bronze.
no argument from me
I think that nut is ripe to be replaced with a better design.
In any event, that thin section is gunna break in cast iron but I'd wager it would break even in bronze - hence my thought to break it properly and design with that.
hmmm, why not? I have an idea in mind that I'll share in a new, project thread.
So the question becomes, do you want another of the same? As in new replacement.
hmmm, maybe not - with some design help, I can do better
Speaking of which, how is the nut lubricated?
There is a ball oiler located directly above the lead screw; squirt and hope that some lands on the lead screw
Sometimes the goldie bronze color can be deceptive if its cast surface or covered in wear sludge or painted at the same time which they are fond of doing.
I had wondered the same thing. Old bronze could easily look like cast iron. The break would be a good place to look.
Definitely not bronze.
7ZV0wST1NUCIpP3aqDt6rJRdoOs7WHTKWATbl2savo1_fnb38ZPrwFRuELvbWXtIirCGzj0niwamD4SCqemsUTtPj9qcrVxk_6DgktScAfsS_OujC5fH2Nv6NfGYBGgovIlTZo9x8u_MgFpZs3_eMOMkoT3FHvEwk7Ed-7rBbD_iExn3y68cz_aki7vWYYefL4zYm5Wj0bBV0a1alOUbmX7jekk9KEMAhWR1y2IOFHZNuPXkUbmyBHpozmKjqVHspiC8nJaUV3V2DX5TKMQuP1UQK6MtdEkxI54u5BNYS81OEUgVaNDbG1tLvVeABTflz4Z6-UDGwKawSVj72V0pe0rewZiVOUIWHhuQbzS5oEkFZu_vhCX-xmXp41lNO31LzuIjq5hSEN7VCnxTWUfSiqAxGXc-p3-SjKjNP3uq2eGU3vdM108FIO1T4u3JF12XS9OJV9hT6F8YWT7Wu_T75yZtivLYxqL6j8CGAqaIEfVs0XYWWIPdX77RIoS-J0IA8dY-VfOZd7NjrtqWIYmpw8aP7sPvJJWkvcm8sEGRzjBHoLKh1LRBUx9MSbNnakmz5XXPj4DA4G_LPHlArLV8GjwSGZD5f2zFSQE0cXeHU9TOwKTnhZEp-2kczx54BDApYLelt6dnf2fG7TESVTmX9w-Gb-Co7PH21FS5DfC3aIp-cdTCnWd8T4kw-SACYBE7j2pfxxi8k2XRkzSayxCZOvZFooxjwfz3f2zYJqBRcbRWoB-cZc2kNVF5hHJNEWlVZyq7gHjsYHhRq_sJ4mesXhDyxiNcAghUMjzMIiDYXRpQW1au4DxEaMoUvNEc7ZPn7uwuxdtTXMg4nWh2gqMLyVgcTTDzC6esQS9ke9hgbAWAu0k0KYZHLwFTWaBKMpGE0bGmKtm6uQU0wKShQcQN3j40Hf-9e28a-2p0E33hWGe7=w610-h933-s-no
What size tap do you need? I have 1/2-10LH and 3/8-10RH acme taps. All you need is a chunk of bronze and a to drill a hole.
Could you reslit the the nut to make it useable until a replacement is ready?
Threads are LH TR10x1.5mm - this tap looks very affordable - https://www.ebay.com/itm/254605460804
There's enough material left to slit the opposite end and drill/tap a new mounting hole. I suspect that this has been broken for some time. Other than frustration induced head slapping, would I damage anything by using it as is while I work out a redesign?
So, unless there's a risk of damage to anything else, I think I'll uses as is while I redesign in bronze; threading with the ebay tap above. Please redirect me if I'm on the way to stupid.
Thanks to all that offered help; the people on this forum are awesome.
I do not think so. You should be just fine. Most of those nuts don't have any provisions for removing backlash at all. Yours has been broken for ages. I cannot see how continuing to use it (without the broken leaf) would do any harm at all. I say go for it!
@curmudgeon - did you get this sorted out?
It might be a bit late now but I know Lenmark in Langley has had Grizzly equipment on their site. Whether they can get parts and at what cost is unknown but might be worth a try.
sadly, no, still unresolved - I have been using it as is and it is frustrating
I priced out some brass at Metal Supermarket and have been pouting ever since.
Thanks for the info about Lenmark.
