BaronJ
Sorry GarzwielerWas just getting ready to post some more photos and yes, it has one big honking capacitor strapped to the outside.
Much clearer look under the hood, I think I've been able to identify some things.
Yellow is the two lines off the capacitor, one going into what I infer is the start coil. The Orange line is the other.
Red and green are the primary coil, and the blue terminals appear to be where the centrifugal switch connects.
I've got a 2P2T switch that I was hoping to use for directionality and innumerable other SPST switches for on/off. Just want to make sure I'm connecting the right stuff in the right spots.
If its got a centrifugal switch you have got a lot more figuring out to do ! Usually that means that it hasn't got a capacitor and that you actually have to rewire the connections so that the run windings are electrically reversed ! That capacitor if it has one may be between two windings, so you have to be careful that when the centrifugal switch opens it doesn't disconnect the whole motor. That would cause the motor to hunt.
Your changeover switch could be used to swap the run coil connections over.
From the picture it looks like you have the changeover switch correct.
