Good info @Tecnico. Leave it to you to find and point this out.
LOL! Always enjoy provoking discussion about interesting topics.
I’m impressed by the discussion this topic has generated, plenty of smart people in the room. I also see that Yuriy has become involved courtesy of
@Susquatch.
Interesting to see the video Yuriy posted on doing the calibration process and the data results.
Not that I understand all of the finer electronic details but it’s informative to see the discussion on the logic of how the measurement is derived/interpreted from the pattern embedded in the tape or glass. Plenty to learn.
One aspect that I’ve seen mentioned peripherally is accuracy of calibrated standards used. One of the factors in arriving at an accurate measurement is doing all of the measurements at a consistent temperature because calibration standards are defined as accurate at just one temperature. When comparing results from various scale samples, that implies the data is only accurate and comparable at the defined standard temperature.
Where am I going with this? In general, for the use that we'll (me) make of our tools we won't usually need to hold dimensions to something like .001" but it appears that the potential is there to experience that much or more error due to temperature differential.
One of the factors which makes a glass scale more attractive to me is the fact that glass has a much lower Thermal Coefficient of Expansion (TCE) than the material used for the magnetic tape. I don't have specifics of the exact glass and mag tape materials but picking data off the web shows Pyrex runs about 4.0 x 10E-6 mm/mm per deg C (or inch/inch since it's just a ratio) while according to the manufacturer, Polyester mag tape (fridge tape) runs about 48 or about a factor of 10 times. This reminds me of one of my lives where I played around with glass for a sensor application because it is thermally stable.
Put practically, if the ambient temp changes by 20C from when the tape was magnetized, the length of the tape could have changed by about .001"
per inch. That also means if you're in
@David_R8 's shop when it's 3000C outside like the other day and laying out a 10" dimension with the DRO then it could be off by something like .010".
I don't know how to quantify simply the effects of the exact composition of the tape, the effects of the stainless strips on either face of it or the 3 adhesive interfaces (whether you've mounted tape in your cross slide or it's on the factory aluminum strongback) or the part of the machine the scale is mounted to but the potential is there to affect the distance between the magnetic "stripes" by temperature in a difficult to quantify manner. It sounds like a detailed FEA that I'll leave to others who have more time to play!
Keeping the scales (machines) at a constant temperature is the obvious way to avoid inducing errors but I'm also thankful that any of the scales I could practically use glass for I did. Only my lathe embedded cross slide and mill quill have magnetic scales. My mill lives in a shop that will probably have 20C temp swings.
So, where does this lead the discussion?
D
