DMC2 Mini Mill - Another build and review
Is there no silkscreen on the old board to cross-reference to the new board?
Hi David
Not that I can read in the instructions. They'll probably send me a mapping diagram later today. Their support has been really good so far.
Day 8
Got the board connections sorted out. They are there but in a slightly different location. So I got those connection sorted and moved on for a couple more steps, just to discover I am missing a lot or wiring (like a parts bag is missing). Another email off to the company and wait for parts.
Happy, happy, joy, joy🙂
Day 9
Still waiting on the wiring to show up (hopefully today), but in the meantime, the machine has found its final home and the mechanical build is complete. Add old laptop and touchscreen and things are starting to shape up.
Day 10
Electrical box attached to the frame, internal components installed and wiring started. Just need some clarification as the motor wire colors are different between the motors and instructions.
Day 10
Steppers are pretty simple. Usually 4 wires, which make up two pairs. To figure which are pairs, connect any two motor wires together and try to turn the motor. If it doesn't turn, that's a pair. If it does turn swap one of the wires out and it should not turn.
I can't tell of those are closed loop steppers but even if they are the motor wiring is the same.
If they are closed loop steppers the encoder will need different wiring but this diagram might help.
Day 11
Machine build complete.
Electrical went smoothly (once I had all the wires).
Next up pre checks, Mach3 and initial run up.
Wiring is a little nasty right now but that'll be sorted when I complete the power panel.
Nice, I have a question or 2:
Where did you get the drip tray? Its a better fit than the Costco one I got (but was only $9).
And what are you planning on doing for work holding? I made a little fixture plate, but I want a vise type device as well, either modular jaws for the fixture plate or a low profile vise. Just looking for what others are thinking.
The tray came from Amaz. WirthCo 22x22. A bit pricy but it'll last. My Machine came with a vise and pins to hold it in place, but I'm planning on a fixture plate as well.
Looks good. Are you ready to make chips?
Not just yet. I did the wiring pre checks and didn't like what I saw. Might have a bad connection so I'll get my electronics guy to double check. Meanwhile I'll get Mach3 all setup and ready to go.
So time for some assistance from anyone who has built this machine and just in general (especially if you know Mach3).
I finally got the machine to the power up stage. Yesterday I had a good connection to the machine but no DMC2 Mini settings. in Mach3. After a clean reinstall of Mach3 and the DMC software, I now have all the settings in Mach3, but no machine connection. Physically, nothing has changed so I would expect it all to work (somewhat). Any thoughts are appreciated.
Cheers
Today I'm lookin for a little assistance with the electrical. Everything is installed, but I'm having issues getting the Y and Z axis to work. X is working just fine from the PC and MPG.
-I've installed furrels on all the wires to eliminate the crimping of the wire casings.
-The 36v S-400-36 power brick is only putting out 34v which I'm not sure is enough, although X is working fine.
-All connections that need it have 34v at their input connections.
-One driver has a flashing green LED on it's board regardless of which axis i put it on.
-switched all the wires around and finally found the right combination to make X work. All the rest SHOUL be the same, but I have tried alternat combination with no luck.
-The Pg Up/Dn keys on the PC work fine, but it does nothing for the Z axis like it should.
I've tried switching the drivers around and get the same result. X=OK, Y=No, Z=No
The Y motor will spin a tiny amount but then it trips.
The board is the newer 2.4 ver and the motors (I think) are 23HS40-5004D-E1K-1M5. The only info on the outer case is in the
20250412_101419.jpg20250412_112902.jpg20250409_165659.jpg20250410_103813.jpg20250412_111325.jpg20250408_155416.jpgpics
I've attached a couple of pics for reference.
Thanks
34v is fine,
I think I've spotted a difference in the wiring of the encoders, the one in your hand is black-ground, red-vcc. the other 2 look like white-ground, red-vcc.
34v is fine,
Yes, I discovered a couple of wiring issues. All fixed. X, Y and Z all work. Now to tackle the Spindle, VFD and tool height gage. Good thing I'm retired or this machine wouldn't be ready until December. Lol
Thanks
Hey Mike R and anyone using Mach3
I'm finally up and running, or almost. I ran the provided bed leveling program from fusion and it almost worked. I have to make the holes again which is not an issue, but they are coming out at half the required diameter.
I checked the Set Steps per Unit, and that's all good.
I also rechecked the fusion file and that looks OK.
Any suggestions?
Any suggestions?
I’d do a google search for how to calibrate Mach 3
Double check your switch settings on the stepper driver, it could be set for double the number of steps per rev which would give you the results you are seeing.
Looking back - mine is set to this starting with switch 1:
OFF, OFF, ON, ON
This corresponds with 1600 steps per rev. everything else is OFF except switch 7 which enables the closed loop control.
OFF, OFF, ON, ON
Thanks Mike. I have it working finally. Just need to fine tune the probe and tool setter.
Cheers and thanks
Well I finally got it all working and completed my first part (see below, speed handle for my mini mill). It's a little rough but ok for a prototype made from a cutting board without the use of the probe or puck. Slight little issue but sorted out now.
To say I learned a lot from this experience would be a massive understatement. I've been learning through this process for months, so here's my thoughts:
Journey & Machine after thoughts:
No initial instructions in the 5 x boxes (link for download provided later) and no parts list (really needed when there are this many parts and some are missing)
1. Mechanical = 98% (only a couple of undersized holes but nothing a larger drill bit couldn't fix).
2. Electrical Install = 75% (The kit was missing a lot of the required wiring).
3. Electrical run up = 50% (this kit came with an upgraded DMC breakout board and upgraded motors, both of which provided more issues than anyone should have to deal with). Eventually it got sorted out with trying different connections and adding a grounding wire between the Mach3 board and the bed.
4. Mach3 install and runup = 80% (A bit of a learning curve for me as this is my first CNC, but after all, it's just software and it definitely has it's own personality. I choose to use it as the machine is setup for it). Note, I got the probe and puck all working fine and left it until the next day to run the first part. When i checked the probe the next day, it was all F%^&*($ up. I changed the screen a couple of times and it sorted itself out, so I believe Mach3 is very electrical field sensitive.
5. Support = 999% ( I would say 1000% but being on the west coast, it takes about a week to get parts). Otherwise it was fantastic. I always received answers withing a day or so with most of the details and fixes I needed. Sometimes I managed to figure it out before they got back to me, but in the end i have no complaints.
Should you buy this machine? You decide as here's the criteria I ended up using:
1. Lots of time, regardless of the 40-50 hour build time as advertised, if you do other things, this will be slow going.
2. Little money as far as CNC purchasing power goes. For the capabilities it has, the price is right.
3. Patients. You will need plenty. There were time I was ready to give up, but i persevered.
In the end, I'm retired so these worked of me and remember to buy LOTS of cheap 3-4mm endmills.
I'm happy I built it as now I have one that works and I know most of the ins and outs. Plus it's CANADIAN made (with I'm sure some parts from elsewhere)
If anyone is building one and has questions, feel free to ask. Or if you're just curious.
Cheers and here's to the next phase - Try to make some spending cash.
