So far only minor issues. Couple of holes out of alignment but a bigger drill fixed that and today I was missing the X axis mounting bolts. Fixed by a trip to the hardware store.Im currently seriously debating/looking at getting one of these. How do you like the kit so far?
zip ties for way covers interesting, sounds like and looks like its coming along nicely for you tho. Im thinking ill be picking one of these kits up this weekDay 3. Way covers, oil lines, bed and start the Z axis assembly.
Issues:
1. Missing X axis mounting bolts (4)M6x45
2. Zip ties to hold the way covers to the linear guides is cheap and fiddley but works (we'll see).
3. Really hard to tighten the Z axis ball screw nut once the assembly is done as per the instructions. Had to remove the ball screw nut bolts and slide it out from behind the red plate, then use a very thin walled 7mm socket to tighten. Then loosen all the red plate bolts to get the ball screw nut back in and tighten all. Need patience here.
Otherwise another stellar day of doing stuff I enjoy.
Cheers all.
It does get a little fiddly at times but it's progressing ok.zip ties for way covers interesting, sounds like and looks like its coming along nicely for you tho. Im thinking ill be picking one of these kits up this week
Thats the same mistake I made, but I got further along before noticing it (mention in post #11 in my thread but not clear, but you can see the misplaced plates in the pictures in the previous posts). Maybe a hint to Shariff to refine the assembly instruction on that step.I noticed a slight screwup after putting the lower shell on. I realized the side skirts were mounted outside the frame and should have been inside, so the lower shell can attach at the back. Too bad all the silicon on the leg nuts was wet. Oh well now my hands are waterproof. Did I mention I dislike silicone.
Funny how I missed that. CheersThats the same mistake I made, but I got further along before noticing it (mention in post #11 in my thread but not clear, but you can see the misplaced plates in the pictures in the previous posts). Maybe a hint to Shariff to refine the assembly instruction on that step.
Thanks Mike. I was planning on just going one motor at a time and yes Mach3 since it's already there and this is my first CNC. Seems there's plenty of reference material around to support it. CheersNice work so far. Are you planning on running Mach3 or something else?
Things to watch out for on electrical if I'm remembering correctly is the instructions are all by wire colour, but the wires on my steppers and encoders were different colours than the manual. Maybe wire up just one motor and get it going (i.e. prove it works) before doing all 3. Will save you having to open everything up to redo the wiring.
Is there no silkscreen on the old board to cross-reference to the new board?Day 8
Figured I'd start some of the electrical work while I wait on the wires for the buttons. Only made it to step 2 and discovered the main board has been updated and the connectors are different. So now we pause again and wait of clarification.
Positive thoughts.🙂
