DavidR8's shop shenanigans
I’ve lived in my house since 82 and have never had a hail claim my brother at the time lived 4 blocks away got hit hard I’ve just had no luck.
Sorry, typo. What a thrash.
I somehow imagined that I could just unscrew the plywood and the framing would magically detach from the exterior wall and the post and poof, wall moved.
Nope, no magic occurred so I had to deconstruct it down to the last stud.
I ran into a snag with my shed build.
Wednesday Home Depot had 60 sheets of LP Smartpanel. Friday they had none. Nor did Lowes or any other building supply.
So my plan to get the shed done so I could move all the wood into it before moving the wall went sideways
Today I said “Sod it I’m moving the wall today.”
Wood that’s currently stored in 1/4 of my garage. Building this basically gives me back a quarter of my garage.
What kind of wood is this David? Surely not 2x4s or plywood. And are you putting wood racks in there now too?
I always wanted to build a wood storage rack in my barn. Bur I never got around to it. Too many things with higher priority. I had wanted something that would handle everything from plywood to 2x12x16 - everything on end but not all leaning on each other. Been 10 years now and hasn't happened yet...... Might not ever happen......
I’m being ruthless in my wood purge so it’s strictly hardwood and some half sheets of Baltic Birch that I’m keeping as a hedge against inflation ;)
I’m not sure about the wood racks. Lee Valley used to carry a nice setup. Need to browse their catalogue again.
Alrighty folks, an update from the shop.
Way back in June I bought plans from Rob Cosman for his workbench. It's specifically designed for handtool woodworking. Then I got Covid, then I had to rebuild the house stairs and finally I built a greenhouse in the backyard. After buying the materials in August, I finally got started on the bench last week.
The base is built from 3/4" Baltic Birch ply strips laminated into two legs and four stretchers. The top is three layers of 1" MDF.
The top weighs 90 lbs and the base is another 90 lbs. It's really solid.
Baltic Birch strips, all cut with my track saw. I was amazed by consistency I managed to get. These are all within 1/64" of the same width.310738585_681764323103088_6751633950808738320_n.jpg
Cut to the required lengths for the glue up.
Two trestles and the top stretchers. The stretchers are secured with 3/8" threaded rod with nuts and washers.
Even with only the top stretchers it did not rack.
The top is glued up in stages with 1-1/2" wood screws and washers on a 6" grid providing the clamping pressure.
This was the part that I was more nervous about because it's a big area to glue and you only get one shot at it.
The bottom layer is cut to the final dimension of 60" x 20" and the subsequent layers are 1/4" over size then trimmed with a bearing bit in a router.
309546194_811424816770582_2203934674425721262_n.jpg312084004_10160050462808828_2833886030567695741_n.jpg
Tonight I hope to glue the final layer on the top.
Then install the vise, cut the vise chop and drill the dog holes and coat with shellac.
