DavidR8's shop shenanigans
Does your boat have an engine?
All boats below 25 feet require a paddle. Even if it is a sailboat, or has a motor. In the straight, it is not good practice to sail without a backup motor. If the tide is contrary, it can save your a**.
There’s one passage where in my Crown 34, flat out against the current I could only do 2 kts over the ground. 15 hp Yanmar pushing a 12x8 two blade prop. I definitely wished for more power Scotty that day.
Made some chips in the new shop :)
I need to put my wood lathe on a mobile base but because it’s nearly four feet long, any mobile base I found was too short.
But there were handy tapped holes in the bottoms of the cast iron legs. Dug through the scrap pile and found these pre-bent chunks of 1/4 aluminum. They came in a box of materials with all those machines I bought years back.
They were exactly the right height for the casters. Drilled a hole for the bolt to thread into the bottom of the leg and enlarged an existing hole for the caster.
Last bins emptied, floor is basically clear now. Just need to build a stand for the sandblast cabinet.
Gotta say, this has been a transformation. I’m bloody tired but very happy with the new space.
Up coming projects:
Finish the Honda CB360T
Build a bookcase for my dearly beloved.
Start cleaning the interior of the boat.
I might start on one of the engines I brought to the last meetup.
