DavidR8's shop shenanigans
I have one of these suspended from the ceiling about 2.5' above my lathe & one hanging behind & slightly above my head at the mill. No significant shadows from either location, tons of light. Picked them up on sale for less than half price. At that distance, there's no chance of anything splashing on them, either.
Do you have a picture of them? The site doesn't have a pic.
@David & @JustaDB The image is fine for me too.
For a non-focussed source, light intensity is inversely proportional to the square of the distance from the source. This means that as you move twice as far away from a light source, the light intensity becomes one-fourth (1/4) as bright.
There is also a difference in perceived intensity between directional and distributed light sources. Again, the perceived light intensity is greater for directional sources.
That's why you need less lumens as the light source gets closer or is more beam like.
LUX is a better comparison than Lumens when comparing how a surface will look with a light shining on it.
With my derelict eyesight, more light is better. I prefer a bright diffused overhead light that lights up the entire work area in combination with a directional light source focussed on the work itself. Someday I'll get around to making a spindle light for the mill, but it's way down on my priorities because my directional magnetic post light really does work great.
I prefer a bright diffused overhead light that lights up the entire work area...
This is why I like those LED's. Being 4' long, they illuminate the entire lathe and the entire mill bed. I do have a small LED bulb on the mill that shines from the left rear & helps w/ shadows on the backside.
Huh. Never saw one like that before.
Engaging/disengaging the drive belt from a handle behind the chuck seems a bit risky to me from the other side of the country. What's it like in real life up close and personal?
I'm with you Susq. That handle is sure too close to the working end of that shaft/chuck for me to use as a stop-go lever. I would add an extension with a bend in it to move the control knob up a bit & over to the front of the lathe...basically you would be lifting the knob straight up from in front of and away from that chuck.
My practice is to never reach near or over the chuck - this means left hand filing, and no touching the lever during movement...
Nice job, that's the quickest way to make them IMO. Now, while you're set up, run off a few more strips, but with some different sized holes, and maybe leave a couple blanks. You have a good little obedient metal eating robot now, so you need some more creative ways to hold it's food for it......
You can make some with a couple different sized holes say 10-24, 1/4-20 all on the same block. They don't "have" to be perfectly centered, especially as they get smaller, but they're really handy for bolting plate/flat work directly through the table, and sometimes you need/only have space for smaller hardware to fit. Things like cutting out 2d profiles become so much easier when you can through bolt it to the table, and you don't always have room for bigger hardware. Even just popping a smaller tapped hole on either side of a regular tee nut can be useful sometimes.
Brilliant idea Dan, really like that!
