@gerritv , @Susquatch the major dia of the tension rod ended up being 0.303" if that sheds some light on the situation.
What was it before threading?
Thats what I saw when I zoomed in, and could see something wasn't right.Hmmm, maybe I have this wrong. If after each DOC thread pass, the tool is retracted out by cross slide, return to start of thread, zeroed to same position (1) then infeed next DOC increment with compound only, then the trailing edge should be the wrong (shallow) angle but more reasonably smooth, not sawtoothy like I drew before.
After. The drill rod was 5/16 so 0.3125 before.
Also, my Emco has radius dials, where my SM has diameter dials.
@PeterT - You would have to superimpose a proper 30 degree thread to see how the diameter gets lopped off.And of course you still have the longer advance and the lopped off diameter.
This is the bolt shank mandrel I threaded with the compound set correctly.....
The total DOC was closer to what I expected. I used a carbide threading tool at 250 RPM. The thread finish isn't great, but better.
that is still within the spec for 1A tolerance on 5/16-24 thread. But it is certainly on the loose end of the fit spectrum.@gerritv , @Susquatch the major dia of the tension rod ended up being 0.303" if that sheds some light on the situation.
Says the guy that doesn't trust digital readouts!That would drive me bonkers.....
I can't wait to install a DRO on my lathe too and leave all that crap behind me.
