TorontoBuilder
Sapientia et Doctrina Stabilitas
So I've been planning for a long time to build a bunch of high end machinist's tool boxes...
BUT I need a lot of storage now and I dislike expensive rolling metal tool chests. I was looking at options when I found a person who created tool chests out of laser cut 1/4" baltic birch plywood. They've released the files on thingiverse.
www.thingiverse.com
Such a tool box is appealing because plywood is inexpensive. It can help control moisture and protect tools within, and it is easy to work with.
If you omit the hardware that protrudes from the chest exterior such chests can be made to slip into a wall unit for large volume storage. You can add cheap laser cut plywood wood boxes, inserts and dividers to the drawers or custom foam cut outs.
Downside, laser cutting in low volumes is not cost effective unless you have a laser cutter.
So would anyone want to participate in a group order/build of one or more of these? Perhaps modifications, etc?
Laser Cut Machinist's Toolbox by drjekyll2k
You can find a full writeup at instructablesThis is a lockable machinist's toolbox I built last year. It is constructed entirely from 1/4 inch baltic birch. The hardware was purchased from Rockler. The exterior was finished with 4 coats of polyurethane varnish while the inside was left...
