Former Member
Guest
Check out Exotic Lumber in Burlington. Prices are actually not bad.
I've shopped exotic woods often... a very good supplier with great websiteCheck out Exotic Lumber in Burlington. Prices are actually not bad.
OSB lacks the strength required to form adequate finger joints and any joints would quickly fail.I see 1/4 OSB in 4x8 is $16. Would that work ? Too heavy yet still too weak?
If the layers between each drawer could be simplified that would save a lot of material. Perhaps two L shapes around the periphery - not sure how to attach and support them. I suppose wooden rails screwed to the sides maybe? Just throwing out some ideas here...
got a link?Probably slightly off-topic. I recently bought a 4 drawer chest from Amaz*n for about $45CDN to hold the small cutters for the CNC mill. The insert trays are 3D printed. The manufacturer makes these little cabinets for artists oil paints and small bits, and it's perfect for a tool crib. Tray depth is about 3/4" Well made from beech.
Cool. ThanksI knew they had a funky name but couldnt recall it.
What is the area of your router? The original laser this was designed to print on has an envelope of just under 24" x 36" so if your cutting envelope is larger you could cut this as laid out IF you adjusted and made dog bones in the corners. Tell me what dimeter you end mill is and I shall modify the file for you
Hmmm I couldn't build that for $45.Probably slightly off-topic. I recently bought a 4 drawer chest from Amaz*n for about $45CDN to hold the small cutters for the CNC mill. The insert trays are 3D printed. The manufacturer makes these little cabinets for artists oil paints and small bits, and it's perfect for a tool crib. Tray depth is about 3/4" Well made from beech.
It is nice, but small and limited. It could work for me as a cabinet insert but I can build 8 drawers to insert into wall unit for that amount. If the storage were for art supplies inside the house that would be a winner. Tools and small parts in garage I need cheaper.Hmmm I couldn't build that for $45.
a 5w laser really wont cut 6.2mm plywood... they're deceptive in their statements. In order to cut 5 mm ply they likely have to use sucha a slow feed rate as to make the laser cutter functionally useless. They also likely require air assist.A 600mm x 600 mm 5w laser popped up on my local FB market place... Specs say it will cut 5mm ply. Amazon has the same model for $500. Thinking of offering $300...
Yeah, I watched a bunch of reviews. It does have air assist but I'd like to be able to reliable cut .25" ply for jig and pattern making and whatnot.a 5w laser really wont cut 6.2mm plywood... they're deceptive in their statements. In order to cut 5 mm ply they likely have to use sucha a slow feed rate as to make the laser cutter functionally useless. They also likely require air assist.
I had issues using my maker spaces much larger CO2 laser to cut 3/8" ply and it was only reliably good and fast at 1/4" plywood. So be cautious and ask if you can test a few cuts before you hand over any cash
