Tool CFM
Tool
Ya know I did an old tractor with a roller and thinned out Tremclad and I was surprised how smooth and well it worked. Much better than the brush job I was doing beforehand. However I have not been impressed by how fast the paint oxidized and went chalky.
To be fair, I have seen some REALLY crappy factory paint jobs over the years!
Anyone here have the paint fall off their GM, while they were trying to figure out Low VOC Paints? They were definitely not the only manufacturer affected, either.
I had a VW that had been looped through the paint line about six times, as best I could tell. When the paint started peeling off in large chips, if you picked up the chip and looked at it under magnification, it looked like one of those stacked layer Licorice Allsort candies. Black, grey, repeating, on down to the metal.
For the price, it's hard to beat Tremclad. But the low price DOES come with a cost too!
I ponder whether a coat of clear, sprayed over the Tremclad, would offset some of the issues with chalking up?
Over the years I have slung Laquer, enamel, poly-urethane, and epoxies, they all have their adaptation curves.
The original post about using Tremclad on the Mopar forum is over 85 pages long now.
Settle in for a while if you read it.
I lived this nightmare.
Basically, the government forced a technogy change before the technology was ready. Everyone who manufactured vehicles in North America was affected.
When the paint came off in sheets, it was all blamed on industry.
I have lots of stories like that.
No thanks. Been through a couple of those cycles on different enthusiast forums... LOL!The problem with both the guys 'for', and the guys 'against', is, as I see it, that they are both usually correct!
For me the method and materials used, will be chosen on a case by case basis, depending on need, want, and purpose! Gotta! If you dig your heels in on one side or the other, eventually you paint yourself into the proverbial corner, and end up using a methodology that is NOT appropriate for the desired end results!
For those of you that recommended the Hobby Aire respirators, did you go with the full face mask or the air supplied hood?
myne is the half face mask, when i bought it there was no option
a full might be nice if you can buy stickys that rip off, other wise i would buy a half, more versatile, you can run whatever goggles, or hood you like that way
You may want to look in to an aftercooler (radiator between the compressor and tank). I am in the process of installing one on my compressor. The cost is much less than a refrigerated dryer and people claim they work well. I have mine configured with 6 240v computer fans set to run when the compressor is running and after the cycle ends until the temperature is 30c. I'm just missing a few plumbing bits to complete the install so I can't offer a review at this point.
