Center drilling problems
Here’s a picture of my holder. Its a fairly large center drill but the holder was’t of any use for anything else. Its has a lot less stick out compared to using a drill chuck. Somehow I did manage to bore a nice tight fit. Its tight enough that air doesn’t leak by the tool.
Ya, I misunderstood your original question.
Frankly, I don't think the loss of accuracy using an end-mill holder is worth worrying about.
Endmill holders work just fine for a crap load of users. I used them for ages on my old MT3 mill/drill and they worked just fine. You can always use a boring bar or a Reamer if you need more accuracy and you would likely have to do that with any holding system (chuck, collet, welden, etc) anyway.
In my opinion, the biggest problem with an end-mill holder is the limited number of sizes. You prolly can't get one for every possible drill size and even if you could you would go broke and run out of tool storage space. So.....
Back to a chuck or a collet......
yah I think an EM weldon shank holder is probably all we gentlemen need - in production though where RPM's are very high also with high surface finish requirements the buzzing of an EM a few tenths or more out of round will have an impact. The other reason for shrink fit or hydraulic holders is to prevent the EM from coming out of the holder. 50HP CNC mills put a lot of torque on an EM. I was reading here: https://www.bigdaishowa.com/en/news...ors-selecting-hydraulic-or-shrink-fit-holders
they say the hydraulic and shrink fit holders are double collets but half of a milling chuck. What is a milling chuck?
I'm very late to this discussion, and it has been super - I thought I'd relate my centre drill and spotting drill experience...
Bert taught me to always use a centre drill on mill or lathe to start a hole because it is far more rigid than a regular twist drill, so it will help in starting a hole in a precise spot. True.
But I'm 'that guy' that questions everything (including myself), so I did a bit of research. I found a pamphlet (before the internet was wide spread) from Mitsubishi about spotting drills, and within a few months had bought one. Sadly that paper seems to be lost in time, but this one is almost as good:
This one is a lot more basic, but their 118 vs 140 paper referenced at the bottom is the best I've seen
To resume the story I bought an inexpensive (but still name brand) HSS spotting drill. This changed my milling and drill press game greatly. The spotting drill is easier to see around when using a loupe to verify location. It is rigid, and makes the perfect hole to start the drill. Since then I've bought cheap offshore carbide ones, and name brand ones and they all work great.
Their use in a tailstock to start a drill operation makes sense also. A spotting drill is closer to the length of the next drill to use, so there's less back-and-forth than using a centre drill.. Less plunging and edge catching too. For very small drills, I confess to using the centre drill nubbin to start things more often than using a spotting drill. old habits die hard...
Not center or spot drilling, but...In the very useful discussion there was a mention of 'opening up' holes -before moving to the boring bar- on the lathe by drilling with successively larger drills. The issue is the edge of the larger drill 'catching' on the 90 degree edge of the smaller hole. I was drilling a couple of small aluminum blocks and found that using a stepped drill (usually for thin sheet) actually worked well for opening up the entry for the larger (1/2") drill. Not recommended but it did work for me. I find that aluminum is 'sticky'; it's easy to get grabbing tools, even if the cutting edge angle/rake has been reduced.
I'm still waiting for the spotting drills from China. Lately, I've been using the one of the turning tools to make a divot for starting the drilling sequence. It helps.
