Not in my experience. Poured my beer into that cardboard box. Tasted bad then seeped through. Would not recommend......yeah, but they make better beverage holders.....![]()
Editing to add cardboard....Not in my experience. Poured my beer into that cardboard box. Tasted bad then seeped through. Would not recommend.
A free cardboard box - ok @fixerup wins!My best cardboard fix was repairing a girlfriend car. She noticed there was almost no heat coming from the fan. I told her to pickup a thermostat and I would fix it after work. When I removed the thermostat housing I tore the gasket apart. So I made one with a cardboard box. I forget if it was a pack of smoke or a laundry box. Tap, tap with a hammer around the thermostat housing, made a gasket and installed the new thermostat. She seemed impressed but didn't believed it would work. Started the car, it didn't leak and we had heat. I told her, to make sure it worked, we needed to wait at least 30 minutes before driving off . So we did spend an hour in the back seat. Best cardboard box fix I ever did.
A free cardboard box - ok @fixerup wins!![]()
Mini spray booth made of cardboard box.
Hey @PeterT what kind of shelving or storage do you use for those boxes? Pictures?My shop revolves around cardboard boxes for parts & item storage. I might have 200 by now. They all have a cheapo masking tape label & I am perpetually shifting contents & location. I used to get 2 specific sizes for free from work that were otherwise destined for recycle. Unfortunately that source has dried up. What's important to me is 1) they are the same width so they stack & you can utilize shelf space 2) easy open lid although I've also used stick on Velcro tabs 3) sufficiently strong box thickness as sometimes its nearly filled with fasteners, metal objects or whatever. For lighter weight stuff I've used shoeboxes which are sometimes consistent width. Amazon boxes are abundant but are the typical top flap which is less convenient when you are in & outa lot. I've made my own lids but they are kind of ugly.
There are nice ones out there, but min qty is kind of a killer. For example these & what's nice is range of taller ones is available on the same footprint. The easy open flap style is what I prefer.
11 1/8 x 8 3/4 x 3
A simple and secure way to send out business forms, binders, catalogs, stationery and magazines. 200 lb. test. Ships flat - sets up in seconds without tape or staples. ULINE offers over 42,000 boxes, plastic poly bags, mailing tubes, warehouse supplies and bubble wrap for your storage...www.uline.ca
I also use boxes for drawer dividers but they compete with dollar store plastic trays. Same problem, trays are always a dimension that almost works but could be better. I've been trying to think of a 3DP component that could allow one to 'make' boxes/trays by cutting rectangles of cardboard from scraps which are always available. Glue guns work well to bond cardboard. But the best I can come up with is essentially 'L' corner stock, kind of like how instrument cases are made. Now that's getting to be more like work though. I can buy a sheet of 1/8" Masonite & make a lot of storage solutions.
John,Spray booth made of a cardboard box. When too much overspray starts coming out of the booth - shut the door. A wIre hanger holds parts up. Turn the wire when you want to rotate the part. Folds down for storage when you are done.
This reminds me of my buddy who produced composite RC models in his garage/shop. He vented externally from a 'booth', sucking through a fan with furnace filters. Even with filters, over time his adjacent fence ~2m away in open air had a buildup of particular paint munge. Must have had forgiving neighbor with no pets. Maybe worse was the (household type) fan motor was not explosion proof. Vapors + Spark = ... Small airbrush type volumes are no issue. Bigger volumes with the nasty paints, maybe give that some downstream consideration.use this ‘box spray booth’ near an open window or ventilation duct
I use the magnifier because it lets me turn on the flashlight and run the camera at the same time. I can't do that with the camera app
