Yes he did.Did he buy your mill?
Lifting platenot sure what you mean. cannot visualize.
I'm not with you on the handcart. I use moving dollies for every heavy load. Usually I just make them custom rather than spending on prebuilt.
The eye bolt is just fine!
Nice outfit! I like!Lifting plate
Are you sure the column doesn't unbolt from the base? I can't picture how they would machine the column with base attached. Sending the knee, column and base down the stairs separately would be a lot safer.Lifting plate
It seems to me the base is cast separate but bolted on and finished with chinese putty and paint to make it look as if it is cast as one unit. I could be wrong but that is what I think I remember seeing.Are you sure the column doesn't unbolt from the base? I can't picture how they would machine the column with base attached. Sending the knee, column and base down the stairs separately would be a lot safer.
On the new ones the column bolts to the base, on the older ones (mine), it's one big solid casting. Looking at the new style at BB today the parting line was obvious.Are you sure the column doesn't unbolt from the base? I can't picture how they would machine the column with base attached. Sending the knee, column and base down the stairs separately would be a lot safer.
I've been meaning to post about it. Knowing how this place likes photos, I've been wanting to transfer some over to this laptop but don't have a thumb drive initialized to it. PITA.Did @JustaDB buy your mill?
.....you flatlanders never could figure those curves out.......I think the trailer wheels touched every half mile or so, usually in the curves where I had to slow down.
One person would have to be the brake and the other the driver to make sure it stays on the sidewalk. Sounds a bit iffy what do you think?
I thought my KBC was one piece as well until I got a look deep inside, turns out the column and base are separate pieces with the seam well bondo'd.On the new ones the column bolts to the base, on the older ones (mine), it's one big solid casting. Looking at the new style at BB today the parting line was obvious.
Was passing every BC plate on the road, sunshine......you flatlanders never could figure those curves out.......![]()
Well with the knee off, probably closer to 500-700lb. One thing for sure, can't afford to let it accelerate. Unfortunately there are no trees in line with that sidewalk.Straight math on a 1000 pounds on a 10/60 grade is 166 pounds trying to race down that hill. One guy acting as brake isn't gunna hold it and the steering guy is gunna get steam rolled. More weight is worse, less weight is better by the pure linear ratio. You would be much better off borrowing @Brent H 's wench. But a winch would be ok too. A cable around a wind lass (tree) might also work.
of the 14 large machines we took out of Berts basement, every one of them had a custom dolly under them, and they were securely strapped and/or bolted to the base of their dolly.
