Dynamic pricing lol
Just looking at it now shows $74 price for me, but locked behind Prime which I don't subscribe to. Sent it over to my neighbour to order and he sees $84. I expect this kind of profiling and dynamic pricing to get worst.
Dynamic pricing lol
I just wanted to get @CWret goingNot happening at $80 Dave.
I ordered 3 of the small M12s and would have ordered a pair of those, but they wanted much bigger $.
I can show you the receipt I honestly paid $80 as the sale price.... just maybe not Canadian peso's 😀
I got my pair for power hungry tools like the die grinder. The problem with switching to a higher voltage tool is that the form factor is also bigger - the reason I’m looking at the M12 3/8 x 13 band file.I see.... I hope it worked! He generally sucks almost full time.
It's OK. At that price I would have bought the pair, but the truth is that I'm not in love with those bigger batteries. I have one of them and I rarely use it. The whole point of M12 is to get a smaller handier tool size. I find the bigger battery works against that a bit. When I need more battery life, I usually shift over to 20V tools.
YOU DID!!!I just wanted to get @CWret going
do you have a link for the Ali
I have the Corded Wen. Its an adequate tool, but its certainly not professional level quality and power. An air band file works much better. The wen is a bit underpowered for metal work but it works if your patient, and use the right quality abrasives. I mostly use it for deburring the insides of tubing, or removing the internal weld for nesting parts. I love my m12 angle die grinder with a roloc so much, I'm sure I'd love the m12 bandfile too, but just can't bring myself to drop that much $$ on a new one. They don't come up used very much, but I keep looking......
Do the tracking adjustment & locking screws thread into metal or plastic? Most of tye negative reviews I saw for the 3/8 x 13 were regarding the threads stripping out. Thanks.The only difference is the belt tracking arm, and that whole assembly is around $160..... Might be a little shop project to make one should the "need" ever arise.
Used, at a pawn shop, and still $225!. I was looking at them at the store and they are $348 new! I'm sure it will be a good tool....but... wow.Well, I picked up a barely used m12 bandfile (the 3/8"x13" one) at a pawn shop today for 225 taxes in.
Thanks, Dan! Since most of the other reviews on Amazon complained about the bare tool not including a battery I doubted that Milwaukee would cheapen up on a potentially frequently used adjustment (unless one never replaced the belt).The tracking adjustment screw threads into steel. And the clamp lever is a bolt on the other side. The only plastic is the housing the entire assembly clamps around.
I don't foresee a problem with me wearing this out with normal and proper use. Some people can break a bowling ball.
lol. My only complaint about it, is that it's a phillips. I might do something about that if it becomes a frustration. I ordered some small bearings today to make the nose wheel for a longer tool arm to take 18" belts. I'll let them acclimatize in the shop with the rest of the stuff I order for projects for a while, and will maybe get to it eventually before I die.....complained about the bare tool not including a battery
Wait! You have a space like that too?! 😀I'll let them acclimatize in the shop with the rest of the stuff I order for projects for a while...
I have many spaces like that.....Wait! You have a space like that too?! 😀
Me, too!I have many spaces like that.....
