Product Band file
Product
Just received mine. Seems well made. Basically a cordless grinder with the belt attachment (even has the handle and the spindle lock still for the angle grinder).
The user manual makes no mention of low battery protection, so I'll assume it has none until I can test it - all my batteries are fully charged.
I didn't even read how the variable speed worked before I bought it. Simple enough and not a bad implementation. One button. Press it and it cycles up then down, then up, etc. through the speeds, with the main switch for On/Off.
Should work well for me.
Great. Thanks @Mike R for sharing. Looks like what I expect to receive tomorrow.
You said it looks to have a grinder backbone but I think their approach makes it longer/thinner and more maneuverable. Please give it a work out and share your experience. 🙂
Edit - Your first impressions of quality?
CW
First impressions are good, I haven't had a chance to use it yet (as in sand something). The gearbox warmed up a bit when I first had it running for a few minutes, but seems to have cooled down and not heating as much. A bit of break-in I guess for the gears.
BTW - when I say it looks like a grinder, well - they make the exact same body as a grinder too:
https://www.amazon.ca/Brushless-Var...g-Polishing/dp/B0G6DJZKZR/ref=sr_1_10?sr=8-10
