Product Band file
Product
I just wanted to get @CWret going
I can show you the receipt I honestly paid $80 as the sale price.... just maybe not Canadian peso's 😀
I see.... I hope it worked! He generally sucks almost full time.
It's OK. At that price I would have bought the pair, but the truth is that I'm not in love with those bigger batteries. I have one of them and I rarely use it. The whole point of M12 is to get a smaller handier tool size. I find the bigger battery works against that a bit. When I need more battery life, I usually shift over to 20V tools.
I got my pair for power hungry tools like the die grinder. The problem with switching to a higher voltage tool is that the form factor is also bigger - the reason I’m looking at the M12 3/8 x 13 band file.
I did knuckle under a bought a 6Ah 12V Bosch battery from Lowes (US$89 with my Military discount: Amazon was US$99 and others were up to US$170 plus shipping!) to use with the 3” Angle Grinder - small form factor and the 6Ah battery should balance OK since it is the recommended battery by Bosch. I have a 3Ah that is the same physical size as the 2Ah if size matters for a job.
Update - the grey Dewalt battery compatible tool I received DOES have low battery detection and cut-off. Thats a nice discovery that I wasn't expecting.
I have the Corded Wen. Its an adequate tool, but its certainly not professional level quality and power. An air band file works much better. The wen is a bit underpowered for metal work but it works if your patient, and use the right quality abrasives. I mostly use it for deburring the insides of tubing, or removing the internal weld for nesting parts. I love my m12 angle die grinder with a roloc so much, I'm sure I'd love the m12 bandfile too, but just can't bring myself to drop that much $$ on a new one. They don't come up used very much, but I keep looking......
Well, I picked up a barely used m12 bandfile (the 3/8"x13" one) at a pawn shop today for 225 taxes in. I've used it a bit this afternoon, and it's every bit as awesome as my m12 right angle die grinder. I was hoping to get the 1/2"x18" model, but i think the little one will be even handier. The only difference is the belt tracking arm, and that whole assembly is around $160..... Might be a little shop project to make one should the "need" ever arise.
Do the tracking adjustment & locking screws thread into metal or plastic? Most of tye negative reviews I saw for the 3/8 x 13 were regarding the threads stripping out. Thanks.
